HOT SWAP THE PLATTE IN SAMSUNG
Posted: 24.06.08, 01:03
by ZeBong
I have a disk Samsung that the MOTOR was OFF.
Patient Samsung 60GB
(change platte + Head + PCB )
Donnor Samsung 80GB
Have change the platte + head + PCB off Samsung 60Gb to the 80Gb.
The 80Gb have the same speed motor.
But now whem i give power to the disk, the head goes in the platte them came back and the platte rotation stop.
What is this problem?
Jose
Posted: 24.06.08, 10:50
by Alex Ivlev
Please send terminal report and model your patient and donnr drive.
Posted: 25.06.08, 00:26
by ZeBong
Hello Alex,
So the model Are:
PATIENT : SP0612N
DONNOR : SP0802N
Jose
Posted: 25.06.08, 11:26
by Igor
Hello ZeBong,
This error
could be caused by ROM and Overlay.
So you need to resolder ROM from patient to donor.
Also it can be uncorrect Swap of the platte.
And one more: it can be uncorrect Swap of the Heads.
So please send/publish terminal report
Regards.
Posted: 26.06.08, 19:20
by ZeBong
Hello Igor,
The PCB is from the patitent.
Head is from the patient.
The platte is from the patient.
When i gove power, it dont detect the disk.
I put MANUAL the family PALO
Can i use the head off the DONNOR that is from 80Gbytes.
Jose
Posted: 27.06.08, 12:56
by Igor
Hello Jose,
Yes you can use the head from such DONNOR(80Gbytes).
Regards.
Posted: 27.06.08, 15:54
by ZeBong
The terminal error is:
SpnOk
DAC:+00074
H: +00000
SK C: 0000DD28
UF: Seq Sk err
H: +00001
UF: 3. 1st Sk err
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 3. 1st Sk err
H: +00000
UF: 3. 1st Sk err
H: +00001
UF: 3. 1st Sk err
ENG>SRV>
Posted: 30.06.08, 00:58
by ZeBong
I check again the platte clean it, but i can not see anything marked in the platte.
Change Head´s twice.
What can i do more ?
Jose
Posted: 21.07.08, 20:35
by ZeBong
Hellor Igor,
Have other disk Samsung 80Gb
Terminal :
HEADS
I test Head´s and head 0 is OK but head 1 is with error
Is possible to change heads, and just work with head 0.
Jose
Posted: 24.07.08, 12:03
by Igor
Hello ZeBong,
1. You need to make Head test and select to make Write process
2. Phisical scan select only read.
I hope it'll help you.
Regards,
