I have a drive that clicks several times and shuts down.
How do I change the head map in RAM so that I can isolate any bad heads?
Can I use the Rom file from another identical drive to do this?
HD204UI clicks then shuts down
Moderator: Garry_TS
Re: HD204UI clicks then shuts down
there is some feature in Samsung utility 'HDD Initialization with head map change in RAM' , try this option
