HD103SJ
Moderator: Garry_TS
avalanche
HD103SJ
Postby avalanche » 24.09.13, 16:32
HDD arrived in with a failed PCB, from inside a desktop computer, HDD has not sustained a physical shock.
Donor PCB + Patient Serial ROM - HDD stays busy, makes a slight buzzing sound. Cannot get access to SA.
Hotwap with donor PCB to Patient - HDD becomes ready, it is possible to read some modules, but not all. Occasionally drive will become busy and make buzzing sound. It will not respond to soft or hard reset. It is necessary to perform another hotswap to get HDD to become ready again. Most likely a weak head?
Terminal output for both situations copied below. Any hits would be greatly appreciated.
Thank you.
DOnor PCB + Patient Serial ROM LOG:
*PA VID=0000 PN=0004 Rev=0001- 785x Found
nd
ChipRev = 63B0
U
S_0
RV En Sensor Circuit
En Shock Sensor Circuit
SO_1
SpinStartUp: mcSpinRPM = 0
RPM at Handoff: 616
Temp : 34 degC
SpinOk
mS1 00000003
SK C:120392 H:0
POK
POK
Boot Sector Error! Take a default.
Error to read FIT header ( 0: 0: 1)
Loaded FIT ( 0: 1: 1)
CalibTable Loaded. Rev:0x14
Selective MARC NX Loaded
ResoTable Loaded. Rev:0x01
Ovly loaded to 0x0001CD00
Ovly loaded to 0x1005B800
FdtTable Loaded. Rev:0x02
| 19 | RLIST | 2 | 0 | 256 | 1340 |
Reading Serial Num Pass
Up MC
TgtCyl: 2032
Hd: 0 Zn: 0 Avg.:- 133
TgtCyl: 264349
Hd: 0 Zn: 1 Avg.: 145
SVCAL(0080,0000)-->PASS
| 147 | IN_SITU | 20 | 0 | 836 | 1140 |
>>InsituStart: t=1463, c=34
| 249 | NINSITUL | 45 | 0 | 2 | 1140 |
GeoId = 49, Idx=49
fodstep: 0000005B dgain: 0000009B
GeoId = 49, Idx=49
fodstep: 00000067 dgain: 000000A7
GeoId = 49, Idx=49
fodstep: 00000063 dgain: 000000AE
GeoId = 49, Idx=49
fodstep: 0000003B dgain: 00000080
GeoId = 49, Idx=49
fodstep: 0000004A dgain: 00000080
GeoId = 49, Idx=49
fodstep: 0000004D dgain: 0000008B
[Bad Size] Increase a sector size in MC!
EPOK
W-MC e(00007704) (20: 0: 864:0x08:0x003F)
EPOK
>>Flag=000002C1 BadHd=0003 dFod=0000 0000 (t=2992 c=34)
| 167 | DRM | 33 | 0 | 0 | 1140 |
| 55 | SMRT | 20 | 0 | 4 | 1340 |
EPOK
EPOK
[DEBUG HALT @MDL_RSRC_BufferAlloc():10034F85 L0 1006FAFB]
[DEBUG HALT @MDL_RSRC_BufferAlloc():10034F85 L0 0000E873]
HOTSWAP LOG:
Occassionally drive will become busy and make buzzing sound. It will nto respond to soft or hard reset. It is
Family selected: F3(SATA)
Model................................... : HD103SJ
Technological ID
Flash version........................... : 1AJ33suM.d26
SA SPT.................................. : 1584
Modules table loaded from SA
Zone allocated table loaded
Service Area
Head map................................ : 0, 1, 2, 3
Part Number............................. : 62821C741A2U7H
Burn-In test............................ : "END" (Status: 0x02, Stop condition: 0x0000)
Executing Standby command
Ok
Recalibration attempt ...
Ok
Reading modules
Into folder............................. : <HDD Profile>\Data\Modules
B3 BOOTSECT............................. : Head: 2, Ok
02 FIT.................................. : Head: 2, Ok
04 MLIST................................ : Head: 2, Ok
00 FSI.................................. : Head: 2, Ok
9B SRVTBL............................... : Head: 2, Ok
B4 RR0_TBL.............................. : Head: 2, Ok
B5 RESO_TBL............................. : Head: 2, Ok
68 FDT_TBL.............................. : Head: 2, Ok
0C CHN_TBL.............................. : Head: 2, Ok
06 CONFIG............................... : Head: 2, Ok
07 SNTBL................................ : Head: 2, Ok
08 BISPT................................ : Head: 2, Ok
0A BIORESLT............................. : Head: 2, Ok
0B FINALTST............................. : Head: 2, Ok
0D GEO_TBL.............................. : Head: 2, Ok
C9 SCT_DATA............................. : Head: 2, Ok
9D PARAM_DM............................. : Head: 2, Ok
A1 PARAM_ER............................. : Head: 2, Ok
B2 PROFILE.............................. : Head: 2, Ok
A4 TUNE_RST............................. : Head: 2, Ok
14 TMPRTR............................... : Head: 2, Ok
74 ATWHDATA............................. : Head: 2, Ok
09 BRSLT................................ : Head: 2, Ok
03 FIT2................................. : Head: 2, Ok
01 FSI2................................. : Head: 2, Ok
73 MOVLY001............................. : Head: 2, Ok
19 BOVLY001............................. : Head: 2, Ok
0F VLIST................................ : Head: 2, Read sector error (c: 1,h:2,s:1331); Device Error Detected
51/40 (UNC)
12 TLIST................................ : Head: 2, Ok
13 ALIST................................ : Head: 2, Ok
11 SLIST................................ : Head: 2, Read sector error (c: 3,h:2,s:1331); Device Error Detected
51/40 (UNC)
29 DLIST................................ : Head: 2, Read sector error (c: 4,h:2,s:1331); Device Error Detected
51/40 (UNC)
A2 DLIST1............................... : Head: 2, Read sector error (c:10,h:2,s:1330); Device Error Detected
51/40 (UNC)
15 SETMAX............................... : Head: 2, Ok
16 SECURITY............................. : Head: 2, Ok
58 SEEKTIME............................. : Head: 2, Ok
17 SRVTBL2.............................. : Head: 2, Ok
6C PTPCCTRL............................. : Head: 2, Ok
86 ROMCODE0............................. : Head: 2, Ok
72 TENBER............................... : Head: 2, Ok
75 BER_REF.............................. : Head: 2, Ok
67 OPTOSD............................... : Head: 2, Ok
41 SPESB0............................... : Head: 2, Ok
42 SPESB1............................... : Head: 2, Ok
43 SPESB2............................... : Head: 2, Ok
65 HDSW................................. : Head: 2, Ok
66 SPIN................................. : Head: 2, Ok
89 HDTK................................. : Head: 2, Ok
8A HDAT................................. : Head: 2, Ok
51 SC_RCO............................... : Head: 2, Ok
1C LATCHFRC............................. : Head: 2, Ok
D3 SSNOISE.............................. : Head: 2, Ok
22 ER_CNT............................... : Head: 2, Ok
23 SV_ERCNT............................. : Head: 2, Ok
25 PAR_MON.............................. : Head: 2, Ok
27 TPI_WRW.............................. : Head: 2, Ok
54 NPV_RSLT............................. : Head: 2, Ok
1E BTIME................................ : Head: 2, Ok
1F ERRTRK............................... : Head: 2, Ok
21 ERRDRV............................... : Head: 2, Ok
8C BER7................................. : Head: 2, Ok
7D BER3................................. : Head: 2, Ok
49 AZLCSM............................... : Head: 2, Ok
AD AZLDCSM.............................. : Head: 2, Ok
28 MRTUNEMT............................. : Head: 2, Ok
8D ATW_CNT.............................. : Head: 2, Ok
63 RCO_LOG.............................. : Head: 2, Read with errors
6D 3DES................................. : Head: 2, Ok
6E ECHOSCRT............................. : Head: 2, Ok
71 SCT_DATA............................. : Head: 2, Ok
37 SMART................................ : Head: 2, Ok
39 SMRT_TST............................. : Head: 2, Ok
3A SMRT_HLG............................. : Head: 2, Ok
BB BLACKBOX............................. : Head: 2, Ok
77 FOD_RST1............................. : Head: 2, Ok
78 FOD_DAT1............................. : Head: 2, Ok
79 FOD_RST2............................. : Head: 2, Ok
7A FOD_DAT2............................. : Head: 2, Ok
7B FOD_RSTH............................. : Head: 2, Ok
7C FOD_DATH............................. : Head: 2, Ok
93 IN_SITU.............................. : Head: 2, Read sector error (c:20,h:2,s: 837); Device Error Detected
51/40 (UNC)
94 IN_BURN.............................. : Head: 2, Ok
3F SV_TRACE............................. : Head: 2, Ok
40 PES_LOG.............................. : Head: 2, Ok
5C PMP.................................. : Head: 2, Ok
A8 MASS................................. : Head: 2, Ok
76 BODE................................. : Head: 2, Read sector error (c:20,h:2,s:1331); Device Error Detected
51/40 (UNC)
2A GEO_00............................... : Head: 2, Ok
AC GEO_0000............................. : Head: 2, Ok
6F VFY_PATT............................. : Head: 2, Ok
7F ATW_CSM.............................. : Head: 2, Ok
8E ATW_CSM2............................. : Head: 2, Ok
8F HALT_HDR............................. : Head: 2, Ok
90 HALT_TST............................. : Head: 2, Read sector error (c:22,h:2,s: 511); Drive is not ready
99 BINEWSCR............................. : Head: 2, Read sector error (c:23,h:2,s: 1); Drive is not ready
9A BINEWSAV............................. : Head: 2, Read sector error (c:23,h:2,s: 641); Drive is not ready
9C SECTDFCT............................. : Head: 2, Read sector error (c:24,h:2,s: 1); Drive is not ready
3D ELOG................................. : Head: 2, Read with errors
A5 OTC_TEST............................. : Head: 2, Read sector error (c:32,h:2,s: 1); Drive is not ready
A6 SDATAMEM............................. : Head: 2, Read sector error (c:32,h:2,s: 36); Drive is not ready
A7 DRM.................................. : Head: 2, Read sector error (c:33,h:2,s: 1); Drive is not ready
A9 AVSCAN............................... : Head: 2, Read sector error (c:38,h:2,s: 1); Drive is not ready
AA TRCK0BKP............................. : Head: 2, Read sector error (c:39,h:2,s: 1); Drive is not ready
B0 CHN_PP............................... : Head: 2, Read sector error (c:40,h:2,s: 1); Drive is not ready
AF SKEWDATA............................. : Head: 2, Read sector error (c:40,h:2,s: 65); Drive is not ready
5E BER_ECC0............................. : Head: 2, Read sector error (c:40,h:2,s: 225); Drive is not ready
5F BER_ECC1............................. : Head: 2, Read sector error (c:40,h:2,s: 265); Drive is not ready
60 BER_ECC2............................. : Head: 2, Read sector error (c:40,h:2,s: 305); Drive is not ready
56 AZLTTPI1............................. : Head: 2, Read sector error (c:40,h:2,s: 345); Drive is not ready
57 AZLTTPI2............................. : Head: 2, Skipped
Test interrupted
avalanche
Re: HD103SJ
Postby avalanche » 24.09.13, 16:44
After a reset of the SMART and A-LIST the following output is given when Donor PCB + Patient ROM. It looks like it is struggling to read the S,R & VList?
*PA VID=0000 PN=0004 Rev=0002- 785x Found
ChipRev = 63B0
U
S_0
SO_1
RPM at Handoff: 921
Temp : 28 degC
SpinOk
mS1 00000003
SK C:117606 H:0
POK
POK
Loaded FIT ( 0: 0: 1)
| 12 | CHN_TBL | 0 | 0 | 40 | 1340 |
[DF_TMOUT0:0000:1000]
| 115 | MOVLY001 | 1 | 0 | 10 | 1340 |
[DF_TMOUT0:0000:1006]
| 17 | SLIST | 3 | 0 | 0 | 1340 |
| 19 | RLIST | 2 | 0 | 256 | 1140 |
| 19 | RLIST | 2 | 1 | 256 | 1140 |
| 15 | VLIST | 1 | 0 | 802 | 1140 |
| 15 | VLIST | 1 | 1 | 802 | 1140 |
| 15 | VLIST | 1 | 2 | 802 | 1140 |
| 18 | TLIST | 2 | 0 | 0 | 1140 |
Up MC
TgtCyl: 2032
#ZoneRty : 1
#ZoneRty : 2
#ZoneRty : 3
#ZoneRty : 4
CalFail
SVCAL(0080,0001)-->PASS
BF
>>InsituStart: t=4261, c=29
| 249 | NINSITUL | 45 | 1 | 2 | 1140 |
| 249 | NINSITUL | 45 | 2 | 2 | 1140 |
GeoId = 49, Idx=49
fodstep: 00000068 dgain: 0000005A
GeoId = 49, Idx=49
fodstep: 00000068 dgain: 00000063
GeoId = 49, Idx=49
fodstep: 00000070 dgain: 00000058
GeoId = 49, Idx=49
fodstep: 00000065 dgain: 00000064
GeoId = 49, Idx=49
fodstep: 00000072 dgain: 00000072
GeoId = 49, Idx=49
fodstep: 00000073 dgain: 00000070
GeoId = 49, Idx=49
fodstep: 00000065 dgain: 00000061
GeoId = 49, Idx=49
fodstep: 00000072 dgain: 00000073
GeoId = 49, Idx=49
fodstep: 00000073 dgain: 00000071
GeoId = 49, Idx=49
fodstep: 0000006E dgain: 0000004C
GeoId = 49, Idx=49
fodstep: 0000006D dgain: 00000054
GeoId = 49, Idx=49
fodstep: 00000073 dgain: 0000004E
GeoId = 49, Idx=49
SR:0
AP:1 C:266721-> 82813 H:2->3 AP Cnt: 0
UF 3 1stGrayErr Hd:3
SK C:263876 H:0
SR:1
AP:1 C:263876-> 82813 H:3->3 AP Cnt: 0
SK C:260993 H:0
SR:2
AP:1 C:260993-> 82813 H:3->3 AP Cnt: 0
SK C:264332 H:0
SR:3
AP:1 C:264332-> 82813 H:3->3 AP Cnt: 0
VOP!
PK_1 C:264332 H:3
SK C:116746 H:3
fodstep: 00000072 dgain: 00000098
GeoId = 49, Idx=49
fodstep: 0000007A dgain: 000000A0
GeoId = 49, Idx=49
fodstep: 00000084 dgain: 00000094
GeoId = 49, Idx=49
SR:0
AP:1 C:266720-> 82813 H:3->3 AP Cnt: 1
SK C:263909 H:0
SR:1
AP:1 C:263909-> 82813 H:3->3 AP Cnt: 1
SK C:261025 H:0
SR:2
AP:1 C:261025-> 82813 H:3->3 AP Cnt: 1
SK C:258159 H:0
SR:3
AP:1 C:258159-> 82813 H:3->3 AP Cnt: 1
VOP!
PK_1 C: 32767 H:3
SK C:114804 H:3
fodstep: 00000072 dgain: 00000093
GeoId = 49, Idx=49
fodstep: 0000007A dgain: 0000009F
GeoId = 49, Idx=49
rb(e1140 20 1 836 13)
rb(e1140 20 2 836 13)
W-MC e(00001140) (20: 2: 836:0x09:0x0093)
EPOK
[DF_TMOUT0:0001:0090]
[DF_TMOUT0:0000:1004]
[DF_TMOUT0:0001:1000]
W-MC e(00007204) (20: 0: 864:0x08:0x003F)
[DF_TMOUT0:0001:0080]
[DF_TMOUT0:0001:108E]
[DF_TMOUT0:0001:0010]
[DF_TMOUT0:0000:0090]
[DF_TMOUT0:0001:0100]
[DF_TMOUT0:0001:0008]
rb(e1140 45 0 2 126)
[DF_TMOUT0:0001:1004]
rb(e1140 45 2 2 126)
[DEBUG HALT @MDL_RSRC_BufferAlloc():10034F75 L0 1005BDB9]
[DEBUG HALT @MDL_RSRC_BufferAlloc():10034F75 L0 0000E65F]
[DEBUG HALT @MDL_RSRC_BufferAlloc():37383538]
