I have ST31000340AS 0MB problem
Moderator: Garry_TS
hamidrcr
Postby hamidrcr » 04.12.09, 23:17
MDL ST31000340AS
FW ST 35
In the beginning this media has BSY problem.
It did resolve but now it is showing me 0MB and unable to fix.
I did refer PC3K user manual and short circuit in PCB as per it said in manual.
Now I am getting following msg.
Test : Solution for problem "Translation violation (0 GB)"
HDD capacity restrict. check (SetMax)...
HDD capacity restrict. check (SetMax)... : Error
SMART erase............................. : Ok
COM port reconnection...
Error : Terminal : error detecting HDD terminal baud rate
Solution for problem "Translation violation (0 GB)"......... : Error
Any one can help me in this case plz.
pcimage
Re: I have ST31000340AS 0MB problem
Postby pcimage » 05.12.09, 22:32
Try doing it manually via terminal, then you can see what's actually happening.
It looks like the utility is struggling with terminal access.
Postby AJ2008 » 07.12.09, 09:53
Yes, try manually. And I also think if you post in correct section you may get better response.
Postby ACE_Admin » 09.12.09, 15:43
Dear Hamidrcr
Before doing anything with PC-3000 utility, first unscrew the pcb and check if PCB has no visual damaged units and contacts between PCB and HDA are not aged. Useful thing is to take a multimeter and same good-known drive's PCB. Check contacts with ground and see, if resistance values are same on donor and on patient's pcb. Different values can be a result of faulty pcb. To make donor board compartible with patient drive, you have to resolder the ROM chip.
But if PCB is good, you may try next: Switch to terminal tab and press ctrl-z. Then try to perform heads test from Tools->User commands->Check heads.
If you will receive errors when checking heads, very likely your patient had head problems.
You can take heads stack from same model drive with same SITE CODE symbols and same or bigger capacity.
