HD400LJ - 400GB PATA
Moderator: Garry_TS
ZeBong
Postby ZeBong » 26.12.08, 17:47
In terminal it appears this info:
SPW 1.5G LinkOk!SpnOk
spd: 0000 0000 0000
ADC: 0001
DAC: 7D88
H: +00000
UF 2 BrkFsamErr
H: +00001
UF 2 BrkFsamErr
H: +00002
UF 2 BrkFsamErr
H: +00003
UF 2 BrkFsamErr
H: +00004
UF 2 BrkFsamErr
H: +00005
UF 2 BrkFsamErr
H: +00000
UF 2 BrkFsamErr
H: +00001
UF 2 BrkFsamErr
H: +00002
UF 2 BrkFsamErr
H: +00003
UF 2 BrkFsamErr
H: +00004
UF 2 BrkFsamErr
H: +00005
UF 2 BrkFsamErr
H: +00000
UF 2 BrkFsamErr
H: +00001
UF 2 BrkFsamErr
H: +00002
UF 2 BrkFsamErr
H: +00003
UF 2 BrkFsamErr
ENG>SRV>
What can i do in this case?
ZeBong
Pepe
Re: HD400LJ - 400GB PATA
Postby Pepe » 31.12.08, 02:03
check pcb, especially power lines to the HDA connector (+5V, -5V),
check the preamp,
if both checks are passed, I suspect some head problem inside...
pepe
Postby AJ2008 » 05.01.09, 10:27
I agree with pepe, probably heads. But check preamp first :D
