WD3200BMVV-11GNWS0 data extraction proplem
Posted: 23.08.15, 02:11
by digital2000
hello dears.
i have HDD :
Model: WDC WD3200BMVV-11GNWS0 Family ( Marn5 4K2.5 ) PCB ( 2060-701675-004 REV P1 )
Serial: WD-WXG1A80N7726
Firmware: 01.01A01
Capacity: 298.09 GB (625 142 448)
every thing is ok but.
i can not extract the data from it , and i have this message when i use data extractor
HFS Volume Header at LBA = 625 120 090
Init virtual HFS+ partition at 625120088
HFS+ Base & BackUp Volume header is invalid
CatalogFile BTree header is invalid
HFS+ partition at LBA = 625 120 088 is append
HFS Volume Header at LBA = 625 128 078
thank you.
Re: WD3200BMVV-11GNWS0 data extraction proplem
Posted: 24.08.15, 12:50
Did you convert this to SATA? I think you converted to SATA and the headers you can find relate to the VCD partition on the disk. The disk will be encrypted with initio encryption. At WD utility in PC3K select 'Sector Edit -> Settings -> Decryption -> Autodetect' and check now if data is displayed correctly at sector 0
