WD Passport Edge 500GB, Slow response and partial head crash
Posted: 15.08.15, 14:36
by CleanestRoom
Hi everyone, i'm stuck and can't get to terminal on this drive:
WD My Passport Edge:
MDL: WD5000LMVW-11CKRS0
S/N: WXP1C42U1994
WWN: 50014EE25CA516DE
DCM: HBCTJHNB
R/N: 771859
Date: 06 SEP 2012
PCB Number: 2060-771859-000
PCB Sticker: 771859-000
Drive has "Slow Response" issue, is mapping slowly.
Drive also has partial head crash, large areas unavailable with rattling/squeeking noise.
In WD Marvell USB Utility, Autodetecting... Error:
"HDDs RAM reading error; unexpected error: Abort command : No Additional Sense Information"
Label:
http://imgur.com/hkI2Sxd
PCB:
http://imgur.com/jqrd6xx
Terminal:
http://imgur.com/32HO8kc
Any help is appreciated.
Re: WD Passport Edge 500GB, Slow response and partial head c
Posted: 17.08.15, 09:57
Probably it is SED with blocked vendor commands
Posted: 18.08.15, 05:01
by CleanestRoom
Figured out how to connect terminal, you need samsung adapter for this drive:
https://i.imgur.com/hQi8Lwg.jpg
https://i.imgur.com/UfgxcVc.jpg
I can read sectors for the minor amount i am able to get.
If it is SED blocking terminal commands, is there anything i can do to get around it?
Thank you for your time.
Posted: 18.08.15, 09:52
CleanestRoom wrote:
I can read sectors
It is SED, and over USB there is nothing you can do. You would need to convert it to a SATA interface then follow the guide posted at this forum by Maxim:
viewtopic.php?f=35&t=8555
