WD1600AAJS-22L7A0 ROM REV 000500EA
Posted: 13.05.15, 21:48
by datasolution
HELLO ALL,
I HAVE PROBLEM WITH THIS DRIVE.DRIVE SPINS NORMALLY BUT DETECTS IN KERNEL MODE.
TERMINAL LOG :
Cyl Count............................... : 170
ROM:
ROM Modules:
ROM version............................. : 05.EAE
ROM F/W version......................... : 000500EA
Overlay F/W version..................... : 05.EAE
Servo F/W version....................... : 04.0B
Heads number in use..................... : 1
Heads map............................... : 0
AFTER LOADING DIR AND LOADER IN RAM IT GIVES ERROR FOR ATA MOD 11.
Module (0011) read error Module ID 11 reading error Data request error - Device Error Detected: "Unknown error code: 3746"
AFTER THIS I GO TO MAIN MENU AGAIN.DETECT FAMILY AND START IN NORMAL MODE WITHOUT USING LOADER,IT DETECTS SPT IT SELF 1311 WHICH IS CORRECT AS ITS FAMILY PINCLITE.BUT STILL REQUIRE LOADER OR PERMANANT OVERLAY NOT FOUND.
TERMINAL LOG :
Techno mode key
RAM:
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM:
ROM Modules:
Service area:
Configuration reading................... : No SA copy avalabled
NOW WHEN I TRIED TO GIVE LOADER FROM DATABASE
Permanent ovl (11) data uploading....... : Ok
WHEN I RESTART UTILTY WITH LOADER ALREDAY LOADED DRIVE GIVES ERR LIKE THIS
Techno mode key
RAM:
ROM:
ROM reading............................. : Module ID 0B reading error; unexpected error: Data request error; unexpected error: -; unexpected error: Operation aborted
Service area:
SA dir reading (ID)..................... : VSC ERR VSC MODE DISABLED
SA dir reading (ABA/CHS)................ : No S/A regions info avalable
PLS HELP ME OR SUGGEST ANY IDEA.
THANKS AGAIN.
Re: WD1600AAJS-22L7A0 ROM REV 000500EA
Posted: 14.05.15, 12:56
Try to write #11 from donor of same version to repair, if it will not write then hotswap it to get data access. If HDD is healthy apart from #11 only, and you cannot fine same #11 version, you can write tracks from donor and restore access to data via writing back of adaptive only modules.
