WD-USB 3.0 key encription data
Posted: 30.10.14, 12:36
by entec
Where is the KEY from this hdd witth Symwave cip USB 3.0 ? i check in my hdd but not found at final of sector hdd ?
Re: WD-USB 3.0 key encription data
Posted: 30.10.14, 15:55
It is never at final sector, it is at a sector that is some specific distance from the end.
for Symwave, check module 38, it will contain a backup of the key, The position on the drive will vary based on capacity of the drive, if you report here capacity I can tell you sector where key is probably located
Posted: 30.10.14, 21:12
by entec
I have this hdd WD3200BMVW-11AMCS0 with pcb 771737-000 and in 38 MOD not have a KEY i hope to find key , how i can do this to DECRYPT data because on USB port not have acces at USER data, i want to recover on SATA mode. Thanks.
