Wd - 500 gb : DRAGFLY1 family
Wd5000AADS - 00S9B0
DCM : HGRNHT2AGN
Techno mode key
Cyl Count............................... : 192
ROM version............................. : 90.82R
ROM generation.......................... : 90.82R
Link table version...................... : 04.0F.
Consolidated ROM version................ : 00900082
ROM Modules:
Modules directory address............... : 75 271
ROM Firmware version.................... : 00900082
Module search process started
Search method........................... : Search by ABA
ABA..................................... : 0
Size in sectors......................... : 184 300
ABA 0 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 1 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 2 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 3 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 4 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 5 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 6 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
Modules found........................... : 0
Module search process completed
How to access modules ? Can anyone Give me loader file ?
Please help
Regards,
micro
WD DRAGFLY1 family : ldr Required
Re: WD DRAGFLY1 family : ldr Required
Short read channels, load utility in 'Normal', enter '1980' as SPT, once loaded you should see message similar to 'SA Dir loading OK' , if yes then you can reach SA now but only by ID (hardware checking). Here you can find module '11' which will be compatible loader
