WD2002FAEX- 007BA0 - Support RAM head map editing?
Posted: 18.06.14, 16:00
Are family Manpl RE supports RAM head map editing?
Techno mode key
ROM version............................. : 05.63F
ROM generation.......................... : 05.63F
Link table version...................... : 01.35.
Consolidated ROM version................ : 00050063
ROM Modules:
Modules directory address............... : 71 895
ROM Firmware version.................... : 00050063
TRY = RAM head map edit
Code type to check...................... : TypeN
Code addr............................... : FFE00000
Code size............................... : 327681
Code reading............................ : RAM Range FFE00000 (050001) reading error Device Error Detected: "VSCE KEY SECTOR MUST PRECEED DATA XFER REQUEST"
No HDD RAM access, LDR upload is recomended
Techno mode key
ROM Modules:
