WD wd10tmvw-11zsms4 ROM regeneration
Posted: 08.05.14, 15:10
Hi Folks,
I've got a wd10tmvw-11zsms4 1TB 2.5" USB drive from a customer today - customer says nothing happened to it just stopped working.
Drive makes noises as if the heads are damaged.
I opened it up in a clean room and didn't see any damage not on the heads and not on the platters.
I didn't have an exact donor but i have the SATA version PCB drive: WD10TPVT.
I executed hotswap using WD10TPVT SATA drive and found the heads to work find and i managed to backup the whole SA with all modules.
I suspect that the ROM on the original PCB is corrupted.
What is the best and easiest way to regenerate the ROM out of the saved modules?
I've tried to click re-generate ROM after SA backup and it gives me the option to choose 109,102,etc.
But then when i choose them the utility prints that these modules are empty????
How can i do it?
Please advise,
How can i do it?
Please advise,
