WD20EARS 60MVWB0 SA OK. head test OK But can't Read LBA .???
Posted: 16.04.14, 10:02
SA test OK.
HEAD test OK.
but :
Translator regeneration
Regeneration method..................... : Use P-List only
P-List Copy 0........................... : Ok
P-List Copy 1........................... : Ok
Error Code : 3C15....................... : FMT PLIST PSN OUT OF RANGE
ROM version............................. : 22.00E
ROM generation.......................... : 22.01E
Link table version...................... : 0B.36.
Consolidated ROM version................ : 00220000
ROM Modules:
Modules directory address............... : 377 654
Heads map............................... : 0,1,2,5,6,7
ROM Firmware version.................... : 00220000
Service area:
Heads test
Cylinder to test........................ : -100
Heads to test........................... : 0,1,2,5,6,7
Head 0.................................. : Ok
Head 1.................................. : Ok
Head 2.................................. : Ok
Head 5.................................. : Ok
Head 6.................................. : Ok
Head 7.................................. : Ok
any solution . thanks for alll
SA test OK.
HEAD test OK.
but :
ROM Modules:
Service area:
Heads test
