hdinfo report
Posted: 04.04.14, 05:15
by drdoc
on the hdinfo report
which parameters do I need to make usre heads from donor are compatible with patient.
Re: hdinfo report
Posted: 04.04.14, 13:36
by rezafarah
for Seagate hdd's:
donor driver should be the same model with same firmware also it is better to have same site code.
some users say that it should have the same head pattern!(to see head's pattern you should have a microscope).
for WD hdd's see this post:
http://ts.acelaboratory.com/index.php?/Knowledgebase/Article/View/27/14/how-to-choose-donor-drive-for-head-swap
Re: hdinfo report
Posted: 28.04.14, 18:20
For seagate, match Site code. It is preferred to match also first 3 letters of SN (assuming donor is from same family), but if Site code is a good match probably donor will be ok with few exceptions
Re: hdinfo report
Posted: 22.08.14, 08:11
by drdoc
hdinfo report is for WDs
