LDR needed for WD5000BPVT-55HXZT3
Posted: 27.01.14, 07:21
by betty
Please anybody have LDR of " WD5000BPVT-22HXZT3" ,update me
betty
crystal
Re: LDR needed for WD5000BPVT-55HXZT3
Posted: 27.01.14, 09:55
You need to specify which fw version it is running. LDR needs to be compatible with ROM at your patient HDD
Posted: 28.01.14, 05:28
by betty
thank u AJ2008,
I am sorry because i need LDR needed for "D5000BPVT-55HXZT3". FW i don't know. because the sticker/Label of Hdd was discarded.So Please Help me
betty
Crystal
Posted: 28.01.14, 10:00
when you enter WD utility, enter Kernel mode and in the log you will see 'ROM Version', the numbers following this represent the version:
ROM version............................. : 65.48K
ROM generation.......................... : 65.48K
Link table version...................... : 05.0H.
Consolidated ROM version................ : 00650048
ROM Firmware version.................... : 00650048
Write here this version and someone can try to help. But you should be aware that using LDR does not work on some new families. What is the symptoms you are seeing? Maybe its something you cannot solve with loader, or maybe something you can solve without one.
Posted: 31.01.14, 07:44
by betty
Hi AJ2008,
Here I am posting the Log:
Techno mode key
Heads number............................ : 3
ROM version............................. : 65.0AB
ROM generation.......................... : 65.0AB
Link table version...................... : 05.0C.
Consolidated ROM version................ : 0065000A
ROM Modules:
Heads number in use..................... : 3
Heads map............................... : 0,1,2
ROM Firmware version.................... : 0065000A
Betty
Crystal
Posted: 31.01.14, 09:46
The version you need is 0065000A.
The closest I have is 00650007 which is not good enough. Hopefully someone else here has it for you.
Posted: 31.01.14, 11:21
by betty
Thanku AJ2008....
I am Waiting for somebody ,those who have the same LDR....
Please help ..
Betty
Crystal
Posted: 31.01.14, 16:20
by rezafarah
i have same ROM but unfortunately for below model:
WDC WD5000BPVT-75HXZT3
Posted: 03.02.14, 09:51
rezafarah wrote:i have same ROM but unfortunately for below model:
If by 'same rom' you mean same version, then module #11 from this resource will be compatible as loader
Posted: 03.02.14, 13:00
by rezafarah
yes AJ2008 i have this ROM version:0065000A for WD5000BPVT-75XZT3
link for module 11 and ROM modules:
http://www.speedyshare.com/JKkZC/downlo ... 75XZT3.rar
Posted: 04.02.14, 07:36
by betty
HI aj2008,
i Download the file.But this files not in recognized in PC3000. So once again upload.
Betty
Crystal
Posted: 04.02.14, 09:53
Extract the files and rename the file called '11' to '11.rpm' then you can use it
Posted: 04.02.14, 18:08
by rezafarah
betty wrote:HI aj2008,
Betty
Crystal
http://speedy.sh/f5qFk/WD5000BPVT-75XZT3.rar
Posted: 06.02.14, 14:24
by betty
module 11 is worked. but ROM Module is not working
Betty
Crystal
