Connecting WD10TMVW through SATA
Posted: 16.12.13, 22:11
by mscerl
How Can I connect the WD10TMVW-11ZSMS1 USB drive to PC-3000 through SATA port?
Re: Connecting WD10TMVW through SATA
Posted: 17.12.13, 08:56
by pcimage
Transfer ROM to a compatible SATA PCB.
Posted: 17.12.13, 21:34
by rezafarah
what is the compatible sata PCB for this model?!
Posted: 18.12.13, 17:54
by waleed
sata 701692
Posted: 19.12.13, 09:55
You need 771692, you can find it on SATA Zephyr, like HXZT series
Posted: 21.12.13, 16:53
by mscerl
is there any way instead of replacing the board?
i've seen someone doing this by soldering special points on the PCB to SATA connector.
it seems that SATA pins are located somewhere on the PCB!
