WD5000BMVW
Posted: 28.11.13, 03:57
by asocla
I've a Usb WD5000BMVW hard disk,
i've changed the heads and the pcb, i've converted the pcf from usb to sata.
I've cloned all disk, but now i don't see any data, because the disk ha a crittography.
is it possible to decrypt the disk with ED?
Re: WD5000BMVW
Posted: 28.11.13, 09:44
by dmarques
What do you mean with ED?
You need the correct WD adapter (Initio, Symwave, JM, etc). You can check that on the patient PCB.
Re: WD5000BMVW
Posted: 29.11.13, 00:27
by asocla
hello
De I can not access the data because of disk encryption.
I would like to know if there is a way to decrypt it without using the original disk pcb patient.
thanks
Re: WD5000BMVW
Posted: 29.11.13, 10:09
by dmarques
Yes, there is. DE (Data Extractor) is not an option, it does not decrypt anything.
You don't need original PCB, but you need an adapter from same encryption chip.
Can you post a picture of the PCB here?
Re: WD5000BMVW
Posted: 30.11.13, 02:18
by asocla
have you an email because the server of acelab sen me this message
"Sorry, the board attachment quota has been reached."
And is not possible to attach the image.
Re: WD5000BMVW
Posted: 02.12.13, 11:09
by dmarques
Send me a PM with your email and I will send you mine.
