Loader file for WD800JD-**TDH** drivre
Posted: 10.10.13, 16:06
by sosrecup
Could anyone provide the loader file for a WD800JD-**TDH** drive please
Kind regards,
Re: Loader file for WD800JD-**TDH** drivre
Posted: 10.10.13, 16:41
Loader will only work if it corresponds with the ROM version of your disk. what is the ROM version?
Posted: 10.10.13, 18:46
by sosrecup
Thank you for your reply.
Do you mean FW version? it's: 02.01C03
But when I read ROM, I get:
View ROM information
ROM Data size........................... : 128 Kb
Firmware version........................ : 40.0SM
Heads map............................... : 0,6
ROM Modules
0A : Heads map
0D : Flash configuration
30 : SA Translator
47 : SA Adaptives
Micro Jogs
LH : PH : Micro Jog (Hex/Dec)
0 : 0 : 6B8/1720
1 : 6 : 64E/1614
