Firebird USB3
Posted: 13.09.13, 10:07
dear guru
hello
i have a usb3 hdd (it is firebird)
when i connect it through usb port , nothing happens
i can read all modules , Rom and tracks with com port
here is the spec:
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 4
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1437
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 256 Kb
>ROM version............................. : 23.2HC
>ROM generation.......................... : 23.2JC
>Link table version...................... : TP.30.
>Consolidated ROM version................ : 0023002H
>ROM Modules:
>Flash ROM dir reading................... : Ok (Active)
>Flash ROM dir reading (Ext)............. : Ok
>Modules directory address............... : 69 093
>SA regions address...................... : by default
>SA Translator loading................... : Ok
!SA defects assigned..................... : 2
>Heads configuration..................... : by map
>Heads number in use..................... : 4
>Switched off heads...................... : No
>Heads map............................... : 0,1,2,3
>ROM Firmware version.................... : 0023002H
>Service area:
>Permanent overlay....................... : Loaded
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
>Configuration reading................... : Ok
>Master Password......................... : has not been set
>User Password........................... : has not been set
to recover the user data what I should I do next ?
best regards
hello
here is the spec:
>Techno mode key
>RAM:
>ROM:
>ROM Modules:
>Service area:
best regards
