WD 2.5 Scorpio Blue (WD5000BEVT-00A0RT0)
Posted: 24.07.13, 16:34
I have a WD 2.5" Scorpio Blue (Model WD5000BEVT-00A0RT0).
When I connect it to PC3000, it is recognized and it reaches readiness. When the drive spin, I can hear a strange sound.
When I run the utility, the model in not recognized and when I choose the model Scoprio, I get the logs bellow:
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM version............................. : 16.0SW
ROM generation.......................... : 16.0SW
Link table version...................... : 07.17.
Consolidated ROM version................ : 0016000S
ROM Modules:
Head Map Reading Error.................. : Head map check sum error
ROM Firmware version.................... :
Service area:
SA dir reading (ID)..................... : DISK SERVO SPINDLE SPINUP ERROR
When I access the Kernel mode, I can read ROM but not SA. when I try to rearch SA by region, I get error and it recommaend to use an LDR file.
Any procedure or solution to resolve the problem please?
Kind regards,
ROM Modules:
Service area:
Kind regards,
