WD4000AAKS-PCB, ROM, SA, Heads OK, ERR AMN - What Next?
Posted: 19.05.13, 17:16
I am working on a WD4000AAKS-00TMA0
Drive spins, does not click, becomes ready and keeps spinning all the time. No funny noises.
Due to the problems as described below I have replaced PCB with one from a working drive (just to eliminate possible faulty PCB) and uploaded ROM - so PCB is presumably OK.
Drive IDs correctly (Tornado) and utility starts in Normal mode.
ROM Tested OK.
All heads (2, 3, 5, 6, 7) tested OK on cylinder -10
SA structure test - All modules OK (except 2D and 2E, not to worry)
Hardware modules checking - all OK
Module 90 reads OK.
I am not posting any of these results as they are OK, if someone wants to see some I'm happy to post them.
Any attempt to read a user data sector (from sector edit) results in ERR AMN. Read SMART times out (with readyness 1000 error). DE hangs trying to read the drive.
Could someone please point me in the right direction from here as I don't know what to do or what to test/correct next? Any hint/piece of advice much appreciated.
ROM Tested OK.
Module 90 reads OK.
