WDC WD7500KMVV-11BG7S0 after HSA replacement
Posted: 16.05.13, 10:31
WD7500KMVV-11BG7S0 with USB interface, replaced HSA due to failed HSA. Connect via USB, spins and stops, shows in Win device manager as USB device. Identifies correctly in PC3000 (Shasta 3D), startup log, hardware modules check and SA structure test below - I have deleted most OK lines due to report length. Notice error in modules 004 and 005 in hardware modules, OK in SA; not sure about the other errors - 2D and 2E errors seem to be common even in working drives of Marvell family. What can I do to make this work?
Techno mode key
Heads number............................ : 5
SA SPT.................................. : 1093
ROM version............................. : 14.A2G
ROM generation.......................... : 14.A2G
Link table version...................... : 05.8E.
Consolidated ROM version................ : 001400A2
ROM Modules:
Heads number in use..................... : 5
Heads map............................... : 0,1,2,4,5
ROM Firmware version.................... : 001400A2
Service area:
Hardware modules checking
Id : Copy 0 : Copy 1 : Desription
0061 : Ok : Ok : Loaded part of microprogram code
0062 : Ok : Ok :
001F : Ok : Ok : Loaded part of microprogram code
006E : Ok : Ok : Loaded part of microprogram code
0116 : Err: 07 : Err: 07 :
0118 : Ok : Ok :
AC55 : Ok : Ok :
003F : Ok : Ok :
006F : Ok : Ok :
0119 : Err: 07 : Err: 07 :
0068 : Ok : Ok :
0069 : Ok : Ok :
006A : Ok : Ok :
0121 : Ok : Ok :
0128 : Ok : Ok :
0120 : Ok : Ok :
0004 : Err: 07 : Err: 07 : Family models configuration (Main)
0005 : Err: 07 : Err: 07 : Family models configuration (Alt1)
0115 : Ok : Ok :
SA Structure Test Report
Id :Copy: Importance: ABA :Size:Read : Hdr : CS : CS Value : Vers. : Desription
006E: 0 : B :209817: 2:Yes : Ok : Ok : 378EADD0 :001400A2:Loaded part of microprogram code
006E: 1 : B :209817: 2:Yes : Ok : Ok : 378EADD0 :001400A2:Loaded part of microprogram code
0116: 0 : : 12500: 6:Yes :Error:Error:8000025D/7FFD3A20: :
0116: 1 : : 12500: 6:Yes :Error:Error:8000025D/7FFBACA6: :
0118: 0 : : 12506: 28:Yes : Ok : Ok : EEE272A3 :001400A2:
002D: 1 : Dr : 9185: 450:Yes : Ok : Ok : 4B3B4919 :001400A2:Debug Log
002E: 0 : B : 9635: 450:Yes :Error: Ok : 9153880D : :Loaded part of microprogram code
002E: 1 : B : 9635: 450:Yes :Error: Ok : 9153880D : :Loaded part of microprogram code
00B5: 0 : Dr : 10085: 160:Yes : Ok : Ok : 14B64FCD :001400A2:WRRO Log Module
003F: 0 : : 10341: 16:Yes : Ok : Ok : 4F44423C :00030000:
003F: 1 : : 10341: 16:Yes : Ok : Ok : 4F44423C :00030000:
006F: 0 : Dr : 10358:2142:Yes : Ok :Error:46EBD63C/BEBE038A:AOZ30000:
006F: 1 : Dr : 10358:2142:Yes : Ok :Error:46EBD63C/BEBE03FF:AOZ30000:
0119: 0 : : 12534: 5:Yes : Ok : Ok : 833A775D :0100....:
Zones number............................ : 257
NN :Beg LBA : End LBA : SPT0 : SPT1 : SPT2 : SPT4 : SPT5
1 :0 : 0 : 1093 : 1093 : 1093 : 1093 : 1093
2 :0 : 40 724 399 : 314 : 312 : 308 : 316 : 253
3 :40 724 400 : 46 654 223 : 314 : 312 : 308 : 316 : 253
4 :46 654 224 : 57 032 311 : 314 : 312 : 308 : 316 : 253
5 :57 032 312 : 60 007 335 : 314 : 312 : 308 : 316 : 253
6 :60 007 336 : 82 351 783 : 314 : 312 : 308 : 316 : 253
7 :82 351 784 : 94 267 815 : 314 : 312 : 308 : 316 : 253
8 :94 267 816 : 116 612 471 : 314 : 312 : 308 : 316 : 253
9 :116 612 472 : 121 088 991 : 314 : 312 : 308 : 316 : 253
10 :121 088 992 : 124 073 119 : 314 : 312 : 308 : 316 : 253
11 :124 073 120 : 140 389 607 : 314 : 303 : 308 : 316 : 253
12 :140 389 608 : 166 954 039 : 314 : 303 : 303 : 316 : 253
13 :166 954 040 : 174 345 047 : 314 : 303 : 303 : 316 : 253
14 :174 345 048 : 175 817 687 : 308 : 303 : 303 : 316 : 253
15 :175 817 688 : 177 285 367 : 308 : 303 : 303 : 308 : 253
16 :177 285 368 : 180 220 479 : 308 : 303 : 303 : 308 : 253
17 :180 220 480 : 193 347 999 : 308 : 303 : 303 : 308 : 245
18 :193 348 000 : 210 874 103 : 308 : 303 : 303 : 308 : 245
19 :210 874 104 : 218 176 863 : 308 : 303 : 303 : 308 : 245
20 :218 176 864 : 222 539 335 : 308 : 303 : 297 : 308 : 245
21 :222 539 336 : 229 812 559 : 308 : 303 : 297 : 308 : 245
22 :229 812 560 : 232 721 791 : 308 : 303 : 297 : 308 : 245
23 :232 721 792 : 245 813 111 : 308 : 303 : 297 : 308 : 245
24 :245 813 112 : 254 517 383 : 308 : 303 : 297 : 308 : 245
25 :254 517 384 : 267 608 479 : 308 : 303 : 297 : 308 : 245
26 :267 608 480 : 280 676 719 : 308 : 303 : 297 : 308 : 245
27 :280 676 720 : 285 014 591 : 303 : 297 : 297 : 308 : 245
28 :285 014 592 : 289 345 607 : 303 : 297 : 297 : 308 : 245
29 :289 345 608 : 305 255 839 : 303 : 297 : 297 : 308 : 245
30 :305 255 840 : 313 933 519 : 303 : 297 : 297 : 308 : 245
31 :313 933 520 : 315 377 631 : 303 : 297 : 297 : 303 : 245
32 :315 377 632 : 324 041 311 : 303 : 297 : 297 : 303 : 245
33 :324 041 312 : 329 773 959 : 303 : 297 : 286 : 303 : 245
34 :329 773 960 : 336 899 511 : 303 : 297 : 286 : 303 : 245
35 :336 899 512 : 338 324 391 : 303 : 297 : 286 : 303 : 236
36 :338 324 392 : 349 713 631 : 303 : 297 : 286 : 303 : 236
37 :349 713 632 : 352 563 391 : 303 : 297 : 286 : 303 : 236
38 :352 563 392 : 361 053 279 : 293 : 297 : 286 : 303 : 236
39 :361 053 280 : 379 451 903 : 293 : 297 : 286 : 303 : 236
40 :379 451 904 : 383 697 743 : 293 : 297 : 286 : 303 : 236
41 :383 697 744 : 393 505 343 : 293 : 288 : 286 : 297 : 236
42 :393 505 344 : 403 319 783 : 293 : 288 : 286 : 297 : 236
43 :403 319 784 : 415 947 575 : 293 : 288 : 286 : 297 : 236
44 :415 947 576 : 427 172 247 : 293 : 288 : 286 : 297 : 236
45 :427 172 248 : 432 793 799 : 293 : 288 : 286 : 297 : 236
46 :432 793 800 : 448 250 647 : 293 : 288 : 286 : 297 : 236
47 :448 250 648 : 449 657 087 : 293 : 288 : 286 : 297 : 236
48 :449 657 088 : 453 879 135 : 293 : 288 : 286 : 297 : 236
49 :453 879 136 : 472 178 231 : 293 : 288 : 286 : 297 : 236
50 :472 178 232 : 480 623 967 : 293 : 288 : 286 : 297 : 236
51 :480 623 968 : 487 613 015 : 293 : 288 : 286 : 289 : 236
52 :487 613 016 : 502 935 535 : 293 : 288 : 279 : 289 : 236
53 :502 935 536 : 504 326 103 : 288 : 288 : 279 : 289 : 236
54 :504 326 104 : 515 384 415 : 288 : 288 : 279 : 289 : 228
55 :515 384 416 : 516 756 679 : 288 : 277 : 279 : 289 : 228
56 :516 756 680 : 527 718 135 : 288 : 277 : 279 : 289 : 228
57 :527 718 136 : 545 557 535 : 288 : 277 : 279 : 289 : 228
58 :545 557 536 : 549 674 327 : 288 : 277 : 279 : 289 : 228
59 :549 674 328 : 551 046 591 : 288 : 277 : 279 : 289 : 228
60 :551 046 592 : 564 769 231 : 288 : 277 : 279 : 289 : 228
61 :564 769 232 : 574 374 055 : 288 : 277 : 279 : 289 : 228
62 :574 374 056 : 583 884 031 : 281 : 277 : 272 : 289 : 228
63 :583 884 032 : 594 702 735 : 281 : 277 : 272 : 283 : 228
64 :594 702 736 : 602 819 487 : 281 : 277 : 272 : 283 : 228
65 :602 819 488 : 605 508 727 : 281 : 277 : 272 : 283 : 228
66 :605 508 728 : 608 213 551 : 281 : 277 : 272 : 283 : 228
67 :608 213 552 : 613 633 223 : 281 : 277 : 272 : 283 : 228
68 :613 633 224 : 631 247 159 : 281 : 277 : 272 : 283 : 228
69 :631 247 160 : 632 602 199 : 281 : 277 : 272 : 283 : 228
70 :632 602 200 : 635 312 311 : 281 : 277 : 272 : 283 : 228
71 :635 312 312 : 639 377 031 : 281 : 277 : 272 : 283 : 228
72 :639 377 032 : 656 902 279 : 281 : 277 : 272 : 283 : 222
73 :656 902 280 : 659 582 839 : 281 : 277 : 272 : 275 : 222
74 :659 582 840 : 660 915 447 : 273 : 277 : 272 : 275 : 222
75 :660 915 448 : 664 901 367 : 273 : 273 : 272 : 275 : 222
76 :664 901 368 : 668 863 479 : 273 : 273 : 264 : 275 : 222
77 :668 863 480 : 678 108 215 : 273 : 273 : 264 : 275 : 222
78 :678 108 216 : 691 314 991 : 273 : 273 : 264 : 275 : 222
79 :691 314 992 : 693 956 399 : 273 : 273 : 264 : 275 : 222
80 :693 956 400 : 695 277 103 : 273 : 273 : 264 : 275 : 222
81 :695 277 104 : 697 900 919 : 273 : 273 : 264 : 275 : 222
82 :697 900 920 : 711 105 639 : 273 : 273 : 264 : 275 : 222
83 :711 105 640 : 725 495 887 : 273 : 264 : 264 : 275 : 222
84 :725 495 888 : 726 802 903 : 273 : 264 : 264 : 275 : 216
85 :726 802 904 : 756 842 663 : 273 : 264 : 264 : 275 : 216
86 :756 842 664 : 758 148 175 : 273 : 264 : 264 : 275 : 216
87 :758 148 176 : 759 454 679 : 273 : 264 : 264 : 275 : 216
88 :759 454 680 : 787 760 775 : 264 : 264 : 264 : 264 : 216
89 :787 760 776 : 801 942 831 : 264 : 264 : 264 : 264 : 216
90 :801 942 832 : 803 221 199 : 264 : 264 : 253 : 264 : 216
91 :803 221 200 : 804 499 567 : 264 : 264 : 253 : 264 : 216
92 :804 499 568 : 809 613 039 : 264 : 264 : 253 : 264 : 216
93 :809 613 040 : 819 839 983 : 264 : 264 : 253 : 264 : 216
94 :819 839 984 : 833 837 391 : 264 : 264 : 253 : 264 : 211
95 :833 837 392 : 842 744 983 : 264 : 264 : 253 : 264 : 211
96 :842 744 984 : 846 562 183 : 264 : 264 : 253 : 264 : 211
97 :846 562 184 : 849 107 239 : 264 : 264 : 253 : 264 : 211
98 :849 107 240 : 859 160 759 : 264 : 250 : 253 : 264 : 211
99 :859 160 760 : 864 195 287 : 264 : 250 : 253 : 264 : 211
100 :864 195 288 : 865 453 927 : 264 : 250 : 253 : 264 : 211
101 :865 453 928 : 886 838 727 : 264 : 250 : 253 : 264 : 211
102 :886 838 728 : 889 339 639 : 264 : 250 : 253 : 264 : 204
103 :889 339 640 : 894 299 255 : 253 : 250 : 253 : 264 : 204
104 :894 299 256 : 906 618 839 : 253 : 250 : 245 : 264 : 204
105 :906 618 840 : 915 149 879 : 253 : 250 : 245 : 252 : 204
106 :915 149 880 : 917 590 199 : 253 : 250 : 245 : 252 : 204
107 :917 590 200 : 921 250 679 : 253 : 250 : 245 : 252 : 204
108 :921 250 680 : 927 350 615 : 253 : 250 : 245 : 252 : 204
109 :927 350 616 : 938 319 495 : 253 : 250 : 245 : 252 : 204
110 :938 319 496 : 943 196 119 : 253 : 250 : 245 : 252 : 204
111 :943 196 120 : 945 640 471 : 253 : 250 : 245 : 252 : 204
112 :945 640 472 : 948 084 823 : 253 : 250 : 245 : 252 : 204
113 :948 084 824 : 964 718 695 : 253 : 250 : 245 : 252 : 204
114 :964 718 696 : 969 459 599 : 253 : 242 : 245 : 252 : 204
115 :969 459 600 : 970 673 839 : 253 : 242 : 245 : 252 : 204
116 :970 673 840 : 973 088 303 : 253 : 242 : 245 : 252 : 198
117 :973 088 304 : 990 922 415 : 240 : 242 : 240 : 252 : 198
118 :990 922 416 : 996 864 767 : 240 : 242 : 240 : 252 : 198
119 :996 864 768 : 999 244 255 : 240 : 242 : 240 : 252 : 198
120 :999 244 256 : 1 008 681 543 : 240 : 242 : 240 : 242 : 198
121 :1 008 681 544 : 1 014 580 695 : 240 : 242 : 240 : 242 : 198
122 :1 014 580 696 : 1 016 940 255 : 240 : 242 : 240 : 242 : 198
123 :1 016 940 256 : 1 021 659 647 : 240 : 242 : 240 : 242 : 198
124 :1 021 659 648 : 1 026 378 903 : 240 : 242 : 240 : 242 : 198
125 :1 026 378 904 : 1 029 891 583 : 240 : 242 : 231 : 242 : 198
126 :1 029 891 584 : 1 042 763 103 : 240 : 242 : 231 : 242 : 198
127 :1 042 763 104 : 1 046 244 631 : 240 : 236 : 231 : 242 : 198
128 :1 046 244 632 : 1 054 350 407 : 240 : 236 : 231 : 242 : 192
129 :1 054 350 408 : 1 055 508 367 : 240 : 236 : 231 : 242 : 192
130 :1 055 508 368 : 1 060 139 791 : 240 : 236 : 231 : 242 : 192
131 :1 060 139 792 : 1 061 297 775 : 240 : 236 : 231 : 242 : 192
132 :1 061 297 776 : 1 068 245 463 : 240 : 236 : 231 : 242 : 192
133 :1 068 245 464 : 1 078 661 551 : 240 : 236 : 231 : 242 : 192
134 :1 078 661 552 : 1 082 135 487 : 240 : 236 : 231 : 242 : 192
135 :1 082 135 488 : 1 089 069 959 : 240 : 236 : 231 : 242 : 192
136 :1 089 069 960 : 1 090 227 943 : 240 : 236 : 231 : 242 : 192
137 :1 090 227 944 : 1 095 974 439 : 240 : 236 : 231 : 234 : 192
138 :1 095 974 440 : 1 109 566 799 : 231 : 228 : 231 : 234 : 192
139 :1 109 566 800 : 1 112 896 991 : 231 : 228 : 218 : 234 : 183
140 :1 112 896 992 : 1 120 667 167 : 231 : 228 : 218 : 234 : 183
141 :1 120 667 168 : 1 122 887 295 : 231 : 228 : 218 : 234 : 183
142 :1 122 887 296 : 1 135 073 911 : 231 : 228 : 218 : 234 : 183
143 :1 135 073 912 : 1 139 514 135 : 231 : 228 : 218 : 234 : 183
144 :1 139 514 136 : 1 145 055 271 : 231 : 228 : 218 : 234 : 183
145 :1 145 055 272 : 1 147 275 399 : 231 : 228 : 218 : 234 : 183
146 :1 147 275 400 : 1 148 385 463 : 231 : 228 : 218 : 234 : 183
147 :1 148 385 464 : 1 156 155 911 : 231 : 228 : 218 : 234 : 183
148 :1 156 155 912 : 1 168 259 791 : 231 : 228 : 218 : 226 : 183
149 :1 168 259 792 : 1 173 735 703 : 231 : 221 : 218 : 226 : 183
150 :1 173 735 704 : 1 180 265 911 : 224 : 221 : 218 : 226 : 183
151 :1 180 265 912 : 1 184 610 831 : 224 : 221 : 218 : 226 : 183
152 :1 184 610 832 : 1 186 787 759 : 224 : 221 : 218 : 226 : 183
153 :1 186 787 760 : 1 192 224 487 : 224 : 221 : 218 : 226 : 183
154 :1 192 224 488 : 1 196 577 975 : 224 : 221 : 218 : 226 : 183
155 :1 196 577 976 : 1 204 127 111 : 224 : 221 : 218 : 226 : 176
156 :1 204 127 112 : 1 210 608 055 : 224 : 221 : 218 : 226 : 176
157 :1 210 608 056 : 1 221 410 911 : 224 : 221 : 218 : 226 : 176
158 :1 221 410 912 : 1 226 752 831 : 224 : 216 : 211 : 226 : 176
159 :1 226 752 832 : 1 227 821 199 : 224 : 216 : 211 : 226 : 176
160 :1 227 821 200 : 1 239 413 599 : 216 : 216 : 211 : 220 : 176
161 :1 239 413 600 : 1 242 573 623 : 216 : 216 : 211 : 220 : 176
162 :1 242 573 624 : 1 245 737 871 : 216 : 216 : 211 : 220 : 176
163 :1 245 737 872 : 1 252 066 039 : 216 : 216 : 211 : 220 : 176
164 :1 252 066 040 : 1 256 270 007 : 216 : 216 : 211 : 220 : 176
165 :1 256 270 008 : 1 262 587 527 : 216 : 216 : 211 : 220 : 176
166 :1 262 587 528 : 1 263 642 279 : 216 : 216 : 211 : 220 : 176
167 :1 263 642 280 : 1 273 134 839 : 216 : 216 : 211 : 220 : 176
168 :1 273 134 840 : 1 276 278 215 : 216 : 209 : 211 : 220 : 176
169 :1 276 278 216 : 1 279 418 191 : 216 : 209 : 211 : 220 : 176
170 :1 279 418 192 : 1 284 612 031 : 216 : 209 : 211 : 211 : 176
171 :1 284 612 032 : 1 285 643 959 : 216 : 209 : 204 : 211 : 176
172 :1 285 643 960 : 1 291 779 495 : 216 : 209 : 204 : 211 : 168
173 :1 291 779 496 : 1 299 956 103 : 216 : 209 : 204 : 211 : 168
174 :1 299 956 104 : 1 303 003 687 : 209 : 209 : 204 : 211 : 168
175 :1 303 003 688 : 1 304 019 031 : 209 : 209 : 204 : 211 : 168
176 :1 304 019 032 : 1 310 114 231 : 209 : 209 : 204 : 211 : 168
177 :1 310 114 232 : 1 318 240 519 : 209 : 209 : 204 : 211 : 168
178 :1 318 240 520 : 1 323 319 855 : 209 : 209 : 204 : 211 : 168
179 :1 323 319 856 : 1 326 367 471 : 209 : 209 : 204 : 211 : 168
180 :1 326 367 472 : 1 328 384 007 : 209 : 209 : 204 : 211 : 168
181 :1 328 384 008 : 1 334 431 111 : 209 : 201 : 204 : 211 : 168
182 :1 334 431 112 : 1 335 439 047 : 209 : 201 : 204 : 211 : 168
183 :1 335 439 048 : 1 341 444 919 : 209 : 201 : 204 : 211 : 168
184 :1 341 444 920 : 1 349 416 007 : 209 : 201 : 198 : 211 : 168
185 :1 349 416 008 : 1 352 401 127 : 209 : 201 : 198 : 204 : 168
186 :1 352 401 128 : 1 357 337 663 : 201 : 201 : 198 : 204 : 168
187 :1 357 337 664 : 1 358 316 847 : 201 : 201 : 198 : 204 : 161
188 :1 358 316 848 : 1 367 129 247 : 201 : 201 : 198 : 204 : 161
189 :1 367 129 248 : 1 370 066 799 : 201 : 201 : 198 : 204 : 161
190 :1 370 066 800 : 1 373 004 351 : 201 : 201 : 198 : 204 : 161
191 :1 373 004 352 : 1 374 962 719 : 201 : 201 : 198 : 204 : 161
192 :1 374 962 720 : 1 377 900 007 : 201 : 201 : 198 : 204 : 161
193 :1 377 900 008 : 1 383 775 095 : 201 : 201 : 198 : 204 : 161
194 :1 383 775 096 : 1 389 640 391 : 201 : 201 : 198 : 204 : 161
195 :1 389 640 392 : 1 391 577 031 : 201 : 192 : 198 : 204 : 161
196 :1 391 577 032 : 1 392 534 743 : 201 : 192 : 187 : 204 : 161
197 :1 392 534 744 : 1 397 322 591 : 201 : 192 : 187 : 204 : 161
198 :1 397 322 592 : 1 401 152 007 : 201 : 192 : 187 : 204 : 161
199 :1 401 152 008 : 1 411 620 151 : 201 : 192 : 187 : 198 : 161
200 :1 411 620 152 : 1 412 563 319 : 192 : 192 : 187 : 198 : 161
201 :1 412 563 320 : 1 416 335 215 : 192 : 192 : 187 : 198 : 161
202 :1 416 335 216 : 1 417 271 295 : 192 : 192 : 187 : 198 : 156
203 :1 417 271 296 : 1 431 299 967 : 192 : 192 : 187 : 198 : 156
204 :1 431 299 968 : 1 432 236 047 : 192 : 192 : 187 : 198 : 156
205 :1 432 236 048 : 1 433 172 079 : 192 : 192 : 187 : 198 : 156
206 :1 433 172 080 : 1 434 095 727 : 192 : 192 : 187 : 198 : 156
207 :1 434 095 728 : 1 441 583 839 : 192 : 192 : 187 : 198 : 156
208 :1 441 583 840 : 1 446 263 151 : 192 : 192 : 187 : 198 : 156
209 :1 446 263 152 : 1 448 114 255 : 192 : 192 : 187 : 188 : 156
210 :1 448 114 256 : 1 454 586 143 : 192 : 192 : 187 : 188 : 156
211 :1 454 586 144 : 1 455 512 383 : 192 : 192 : 187 : 188 : 156
212 :1 455 512 384 : 1 462 845 047 : 192 : 183 : 187 : 188 : 156
213 :1 462 845 048 : 1 465 562 063 : 192 : 183 : 187 : 188 : 149
214 :1 465 562 064 : 1 467 366 559 : 192 : 183 : 180 : 188 : 149
215 :1 467 366 560 : 1 474 572 511 : 192 : 183 : 180 : 188 : 149
216 :1 474 572 512 : 1 475 471 791 : 192 : 183 : 180 : 188 : 149
217 :1 475 471 792 : 1 482 536 279 : 183 : 183 : 180 : 188 : 149
218 :1 482 536 280 : 1 487 871 479 : 183 : 183 : 180 : 188 : 149
219 :1 487 871 480 : 1 493 206 615 : 183 : 183 : 180 : 188 : 149
220 :1 493 206 616 : 1 494 095 815 : 183 : 183 : 180 : 188 : 149
221 :1 494 095 816 : 1 499 430 975 : 183 : 183 : 180 : 188 : 149
222 :1 499 430 976 : 1 501 209 359 : 183 : 183 : 180 : 188 : 149
223 :1 501 209 360 : 1 508 322 367 : 183 : 183 : 180 : 188 : 149
224 :1 508 322 368 : 1 511 841 951 : 183 : 183 : 180 : 180 : 149
225 :1 511 841 952 : 1 512 714 991 : 183 : 176 : 180 : 180 : 149
226 :1 512 714 992 : 1 515 334 095 : 183 : 176 : 180 : 180 : 149
227 :1 515 334 096 : 1 519 659 103 : 183 : 176 : 172 : 180 : 149
228 :1 519 659 104 : 1 526 516 031 : 183 : 176 : 172 : 180 : 144
229 :1 526 516 032 : 1 529 948 655 : 183 : 176 : 172 : 180 : 144
230 :1 529 948 656 : 1 530 800 175 : 176 : 176 : 172 : 180 : 144
231 :1 530 800 176 : 1 533 351 863 : 176 : 176 : 172 : 180 : 144
232 :1 533 351 864 : 1 534 194 599 : 176 : 176 : 172 : 180 : 144
233 :1 534 194 600 : 1 543 560 855 : 176 : 176 : 172 : 180 : 144
234 :1 543 560 856 : 1 547 810 991 : 176 : 176 : 172 : 180 : 144
235 :1 547 810 992 : 1 548 661 007 : 176 : 176 : 172 : 180 : 144
236 :1 548 661 008 : 1 550 361 095 : 176 : 176 : 172 : 180 : 144
237 :1 550 361 096 : 1 560 544 839 : 176 : 176 : 172 : 180 : 144
238 :1 560 544 840 : 1 561 385 767 : 176 : 176 : 172 : 172 : 144
239 :1 561 385 768 : 1 566 387 903 : 176 : 176 : 172 : 172 : 138
240 :1 566 387 904 : 1 567 214 087 : 176 : 168 : 172 : 172 : 138
241 :1 567 214 088 : 1 576 195 759 : 176 : 168 : 165 : 172 : 138
242 :1 576 195 760 : 1 577 014 007 : 176 : 168 : 165 : 172 : 138
243 :1 577 014 008 : 1 581 909 255 : 176 : 168 : 165 : 172 : 138
244 :1 581 909 256 : 1 583 545 655 : 176 : 168 : 165 : 172 : 138
245 :1 583 545 656 : 1 590 824 487 : 168 : 168 : 165 : 172 : 138
246 :1 590 824 488 : 1 593 252 135 : 168 : 168 : 165 : 172 : 138
247 :1 593 252 136 : 1 597 278 775 : 168 : 168 : 165 : 172 : 138
248 :1 597 278 776 : 1 598 894 015 : 168 : 168 : 165 : 172 : 138
249 :1 598 894 016 : 1 604 547 719 : 168 : 168 : 165 : 172 : 138
250 :1 604 547 720 : 1 609 353 615 : 168 : 168 : 165 : 172 : 132
251 :1 609 353 616 : 1 612 518 343 : 168 : 168 : 165 : 163 : 132
252 :1 612 518 344 : 1 614 081 031 : 168 : 158 : 165 : 163 : 132
253 :1 614 081 032 : 1 622 558 103 : 168 : 158 : 156 : 163 : 132
254 :1 622 558 104 : 1 626 414 999 : 168 : 158 : 156 : 163 : 132
255 :1 626 415 000 : 1 627 289 999 : 168 : 158 : 156 : 163 : 132
256 :1 627 289 999 : 1 627 289 999 : 161 : 158 : 156 : 163 : 132
257 :1 627 289 999 : 1 627 289 999 : 161 : 158 : 156 : 163 : 132
Physical zone allocation table
Zones number............................ : 21
NN : 0 : 1 : 2 : 4 : 5
: Beg Cyl : End Cyl : SPT : Beg Cyl : End Cyl : SPT : Beg Cyl : End Cyl : SPT : Beg Cyl : End Cyl : SPT : Beg Cyl : End Cyl : SPT
0 : -256 : -1 : 1 093 : -256 : -1 : 1 093 : -256 : -1 : 1 093 : -256 : -1 : 1 093 : -256 : -1 : 1 093
1 : 0 : 14 120 : 314 : 0 : 10 331 : 312 : 0 : 11 684 : 308 : 0 : 13 685 : 316 : 0 : 17 282 : 253
2 : 14 121 : 22 880 : 308 : 10 332 : 23 492 : 303 : 11 685 : 18 203 : 303 : 13 686 : 24 832 : 308 : 17 283 : 32 726 : 245
3 : 22 881 : 28 880 : 303 : 23 493 : 32 348 : 297 : 18 204 : 27 182 : 297 : 24 833 : 30 663 : 303 : 32 727 : 49 862 : 236
4 : 28 881 : 41 720 : 293 : 32 349 : 43 973 : 288 : 27 183 : 41 489 : 286 : 30 664 : 38 943 : 297 : 49 863 : 64 217 : 228
5 : 41 721 : 47 960 : 288 : 43 974 : 57 241 : 277 : 41 490 : 49 301 : 279 : 38 944 : 48 018 : 289 : 64 218 : 73 642 : 222
6 : 47 961 : 55 520 : 281 : 57 242 : 61 953 : 273 : 49 302 : 57 609 : 272 : 48 019 : 54 588 : 283 : 73 643 : 84 252 : 216
7 : 55 521 : 64 640 : 273 : 61 954 : 75 221 : 264 : 57 610 : 70 629 : 264 : 54 589 : 64 130 : 275 : 84 253 : 91 990 : 211
8 : 64 641 : 76 880 : 264 : 75 222 : 86 877 : 250 : 70 630 : 79 681 : 253 : 64 131 : 78 398 : 264 : 91 991 : 102 064 : 204
9 : 76 881 : 85 160 : 253 : 86 878 : 95 061 : 242 : 79 682 : 87 741 : 245 : 78 399 : 87 920 : 252 : 102 065 : 111 408 : 198
10 : 85 161 : 97 760 : 240 : 95 062 : 100 765 : 236 : 87 742 : 93 321 : 240 : 87 921 : 97 592 : 242 : 111 409 : 119 438 : 192
11 : 97 761 : 106 160 : 231 : 100 766 : 108 825 : 228 : 93 322 : 102 249 : 231 : 97 593 : 104 908 : 234 : 119 439 : 130 972 : 183
12 : 106 161 : 112 160 : 224 : 108 826 : 114 901 : 221 : 102 250 : 114 897 : 218 : 104 909 : 113 092 : 226 : 130 973 : 143 236 : 176
13 : 112 161 : 120 440 : 216 : 114 902 : 120 977 : 216 : 114 898 : 122 337 : 211 : 113 093 : 119 168 : 220 : 143 237 : 153 602 : 168
14 : 120 441 : 126 680 : 209 : 120 978 : 127 673 : 209 : 122 338 : 129 281 : 204 : 119 169 : 127 724 : 211 : 153 603 : 162 508 : 161
15 : 126 681 : 134 000 : 201 : 127 674 : 135 361 : 201 : 129 282 : 135 605 : 198 : 127 725 : 134 278 : 204 : 162 509 : 169 758 : 156
16 : 134 001 : 142 280 : 192 : 135 362 : 144 041 : 192 : 135 606 : 145 401 : 187 : 134 279 : 140 182 : 198 : 169 759 : 179 038 : 149
17 : 142 281 : 149 720 : 183 : 144 042 : 151 811 : 183 : 145 402 : 152 308 : 180 : 140 183 : 148 623 : 188 : 179 039 : 186 094 : 144
18 : 149 721 : 157 400 : 176 : 151 812 : 159 683 : 176 : 152 309 : 159 811 : 172 : 148 624 : 155 984 : 180 : 186 095 : 193 691 : 138
19 : 157 401 : 164 064 : 168 : 159 684 : 166 694 : 168 : 159 812 : 166 945 : 165 : 155 985 : 163 104 : 172 : 193 692 : 203 228 : 132
20 : 164 065 : 168 943 : 161 : 166 695 : 174 197 : 158 : 166 946 : 174 202 : 156 : 163 105 : 170 645 : 163 : 203 229 : 203 796 : 127
MODULES DIRECTORY (01)
SA Copy num Location State
0 0 (24) Ok
1 0 (24) Ok
Modules number.......................... : 435
CONFIGURATION MODULE (02)
0 207 913 (4) Ok
1 207 913 (4) Ok
HDD Identify
Model................................... : WDC WD7500KMVV-11BG7S0
Serial number........................... : WD-WX31A70X3593.....
Logical parameters...................... : LBA : 1 465 149 167
Master-password
Set..................................... : No
User-password
Security level.......................... : High
Log DCM (C5)
0 85 282 (150) Ok
1 85 282 (150) Ok
SHASTA3D
+--- Head DCM Codes -------- Media DCM Codes -----+
| SAE S6: B | SHOWA GL: S |
| SAE S63: C | SHOWA AL: T |
| WDB LD37: D | WDMO GL : K |
| WDB D60: E | WDMO AL: L |
| WDB D60A: F | |
| WDB D60B: G | |
| SAE WF94: H | |
Relo-List (32)
0 4 651 (32) Ok
1 4 651 (32) Ok
Defects number.......................... : 0
P-List (33)
0 584 (2567) Ok
1 584 (2567) Ok
Defects number.......................... : 5636
G-List (34)
0 4 639 (12) Ok
1 4 639 (12) Ok
Techno mode key
ROM Modules:
Service area:
0062 : Ok : Ok :
0118 : Ok : Ok :
AC55 : Ok : Ok :
003F : Ok : Ok :
006F : Ok : Ok :
0068 : Ok : Ok :
0069 : Ok : Ok :
006A : Ok : Ok :
0121 : Ok : Ok :
0128 : Ok : Ok :
0120 : Ok : Ok :
0115 : Ok : Ok :
0 0 (24) Ok
1 0 (24) Ok
0 207 913 (4) Ok
1 207 913 (4) Ok
HDD Identify
Master-password
User-password
Log DCM (C5)
0 85 282 (150) Ok
1 85 282 (150) Ok
SHASTA3D
| WDB D60A: F | |
| WDB D60B: G | |
| SAE WF94: H | |
Relo-List (32)
0 4 651 (32) Ok
1 4 651 (32) Ok
P-List (33)
0 584 (2567) Ok
1 584 (2567) Ok
G-List (34)
0 4 639 (12) Ok
1 4 639 (12) Ok
