WD30EZRX
Posted: 28.01.13, 08:23
WD30EZRX
3.0 TB
initially in busy state making noise like head stuck
when i run WD utility following log
Techno mode key
Techno mode key:........................ : Techno key error; unexpected error: Drive is not ready
Debug Stop Code......................... : HOST DEBUGSTOP RESET TIMEOUT
RAM:
HDD Info reading........................ : HDDs RAM reading error - Device Error Detected: "VSCE VSC MODE DISABLED"
ROM:
ROM version............................. : 20.1UP
ROM generation.......................... : 20.1UP
Link table version...................... : 0B.38.
Consolidated ROM version................ : 0020001U
ROM Modules:
Flash ROM dir (ext) reading............. : Ok (Active)
Modules directory address............... : 283 719 (24)
Heads number in use..................... : 8
Heads map............................... : 0,1,2,3,4,5,6,7
ROM Firmware version.................... : 0020001U
Is it FW issue?
3.0 TB
Techno mode key
RAM:
ROM:
ROM Modules:
Is it FW issue?
