Europa
Posted: 27.12.12, 20:46
Any general advice when dealing with this Europa family when it has corrupted firmware? Most of the standard tricks don't yield any fruit.
For example:
1. Heads Map editing in RAM doesn't work (even on healthy drives, with either the new algorithm or the old)
2. Disabling SA Access by shifting the SA Region and using a loader does not allow any SA access (even on a healthy drive using its own 11, it will fail loading the flash ROM dir module 0B and fail to load SPT)
3. When dealing with bad firmware when you can access by ID, it seems that while you can read the healthy modules (no option for ignoring errors in ID mode for some reason?) you can't successfully write back by ID (it says "OK" but never sticks).
4. Hot-swaps on these drives always immediately tick on restart. Even when your donor is the same firmware and same heads map. On a current case I've even written every module but 33/31 (which are bad) to my donor.. donor boots OK with patient s/n and still immediately ticks and dies on hotswap... so it isn't related to adaptives in SA or ROM.
Only thing physically about these Europas that is different seems to be that the heads screw into the chassis instead of free floating on a post. I'm thinking this is somehow involved in their odd behavior?
For example:
