Rom and Modules for WD3200AAKS
Posted: 13.11.12, 22:15
by 619data
WD3200AAKS-00UU3A0
Date: 05 MAY 2010
DCM: HGNNTJAHN
If you need any other number, I will provide them
Thanks in advanced,
Re: Rom and Modules for WD3200AAKS
Posted: 14.11.12, 15:42
Repairs to service area objects are in most cases totally dependant on matching the firmware revision, we need to know the revision of your patient HDD
Posted: 14.11.12, 22:56
by 619data
The firmware version is 3.0B
Posted: 15.11.12, 16:40
Where do you find this code?
FW should be similar to "00000023" and ROM should look like "00.23B"
I never see simply '03B' before. Do you read header from mod #11, or select 'View Module 90 information" option?
Posted: 15.11.12, 18:07
by 619data
Here we go:
Techno mode key
ROM version............................. : 00.0JB
ROM generation.......................... : 00.0JB
Link table version...................... : 03.0B.
Consolidated ROM version................ : 0000000J
ROM Modules:
Flash ROM dir (ext) reading............. : Ok (Active)
Modules directory address............... : 156 336 (24)
ROM Firmware version.................... : 0000000J
View module 90 information
Total heads............................. : 2
Used heads.............................. : 2
Mdl 47 version.......................... : FU.0021
ROM Version version..................... : 0000000J (00.0J)
Mdl 11 Version.......................... : 0000000J (00.0J)
Thanks for the help,
