WD2500JD-75HBB0 Clicking, no access to SA
Posted: 18.05.12, 00:50
Hey Guys, heres the deal. The drive clicks 3 rounds of 10 clicks then it powers down, DRD DSC.
Donor:
WD2500JD-75HBB0
Date: 24 Jul 2004
DCM: HSBACTJAA
Malaysia
ROM: 08.DHD
Patient:
WD2500JD-75HBB0
Date: 24 Jul 2004
DCM: HSBACTJAA
Malaysia
ROM: 08.1HD
Techno mode key:
HDD geometry loading.................... : Ok
Cyl Count............................... : 87921
Head Count.............................. : 1
SPT..................................... : 900
ROM version............................. : 08.1HD
ROM generation.......................... : ......
Link table version...................... : 02.A9.
Heads configuration..................... : From map
The number of heads in use.............. : 6
Disabled heads.......................... : No
Head map................................ : 0,1,2,3,4,5
Service area:
Modules table loading................... : SA Directory checksum error
Configuration loading................... : Module 42 not found in modules directory
Translation overlay checking (Copy 0)... : Not found in modules directory
Translation overlay checking (Copy 1)... : Not found in modules directory
I swaped ROMS and the patient PCB works on the donor drive so it doesnt appear to be a PCB issue. The donor PCB with the patient ROM on the patient drive doesnt stop it from clicking.
I tried RAM head map editing and the drive always clicks after a soft reset.
The drive always seems to make the same type of clicking noise no matter what I do.
Not sure what to try next besides swapping the heads.
Donor:
WD2500JD-75HBB0
Date: 24 Jul 2004
DCM: HSBACTJAA
Malaysia
ROM: 08.DHD
Patient:
WD2500JD-75HBB0
Date: 24 Jul 2004
DCM: HSBACTJAA
Malaysia
ROM: 08.1HD
Techno mode key:
Service area:
