Can't restore drive after using it for smart hotswap
Posted: 28.02.12, 04:44
I used a WD20EARS-0MVWB0 to smart hot swap a similar drive (it worked, that's done). The problem I'm having (and often have after smart hotswap -- moving all patient tracks to donor) is restoring the drive back to it's default state. I always just try writing all the service tracks back to the drive, but it often either doesn't finish or gets too slow to finish, like writing 1 track every 10 hours.
With this current drive, I tried writing it's original backup tracks back. It took about 20 hours to move them all back (at first was fast, then got slower towards the end). Now the drive comes ready with no ID and no SA copy available:
Techno mode key
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM version............................. : 22.00E
ROM generation.......................... : 22.00E
Link table version...................... : 0B.36.
Consolidated ROM version................ : 00220000
ROM Modules:
Flash ROM dir (ext) reading............. : Ok (Active)
Modules directory address............... : 377 654 (24)
Heads map............................... : 0,1,2,5,6,7
ROM Firmware version.................... : 00220000
Service area:
Configuration reading................... : No SA copy avalabled
Trying to write tracks says I need a Loader. I've tried every loader in DB (including the original loader for this drive and the patient drive), but all give some error and do not work.
What else can I try?
What is the proper procedure to restore donor tracks back to donor so its working again after smart hotswap?
Thanks!
Techno mode key
ROM Modules:
Service area:
Thanks!
