1600AAJS-75B4A0 Pinnacle SA issues
Posted: 10.02.12, 17:09
So I have a pinnacle that is behaving different then any I have personally seen before.
It powers up, make normal sounds but stays busy.
after ~3 minutes, similar to the Sadle G6 family, it will read ERR ABRT.
Here is where it gets interesting to me.
I have a perfect matching donor, using LDR file I can get into normal mode, but it will read "No SA copy available"
hardware modules check reads modules, but says there is a checksum issue with all modules except for 01.
If i try to do SA structure test all modules fail to read.
if I attempt to open any single module to view it in modules directory, it will not open.
So I did a "module search" using both methods gives me the same results, it finds the entire SA, and I can read each module and headers are in correct place, etc.
If I then select "use this dir in modules directory" option (forgot the exact syntax on that option) I can now do SA structure test and all modules pass.
So my question is, what is my next step here? Should I rewrite the found modules back to the drive?
Thanks!
Thanks!
