WD20EARX donor lost after writing Mod 01
Posted: 24.01.12, 16:04
by rcz
I wanted to do a hot-swap with a WD20EARX.
I checked compatibility (averaged Microjogs) -> ok
I wrote Mod 01 by ID from patient to donor -> ok
Off/On donor -> Now I can't get drive ID, I can't get SA SPT (so I put it manually - 1980). I can't neither write any modules, nor use loader (drive restart when I start loader and I get an error).
I wonder if this method is useable on Sadle G6, I had the same problem on a WD20EARS.
An idea ?
Re: WD20EARX donor lost after writing Mod 01
Posted: 25.01.12, 09:15
by hassan
Did you try to write modules by ID?
Posted: 25.01.12, 13:37
by rcz
Yes, I can't.
Posted: 25.01.12, 13:52
by hassan
try to write other rom version and restore the original rom modules (0A,47,..
and try to read module by ID
Posted: 10.02.12, 15:55
by rcz
Here it is (sorry for delay, I was in holiday):
Reading modules
Into folder............................. : <HDD Profile>\Data\Modules\
Module : 35............................. : Ok
Module : 33............................. : Ok
Module : 31............................. : Ok
Module : 0C............................. : Ok
Module : 34............................. : Ok
Module : 32............................. : Module ID 32 reading error Data request error - Device Error Detected: "FM ERR CHECKSUM"
Module : 36............................. : Module ID 36 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 29............................. : Module ID 29 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 40............................. : Module ID 40 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 41............................. : Ok
Module : 42............................. : Ok
Module : 43............................. : Ok
Module : 4E............................. : Ok
Module : 49............................. : Ok
Module : 4A............................. : Ok
Module : 4D............................. : Ok
Module : 03............................. : Ok
Module : 25............................. : Ok
Module : 26............................. : Ok
Module : 38............................. : Ok
Module : 39............................. : Ok
Module : 37............................. : Ok
Module : 2D............................. : Ok
Module : 2E............................. : Ok
Module : B5............................. : Ok
Module : 6B............................. : Ok
Module : 3A............................. : Ok
Module : 28............................. : Ok
Module : 3B............................. : Ok
Module : 3C............................. : Ok
Module : 3D............................. : Ok
Module : 3E............................. : Ok
Module : 3F............................. : Ok
Module : 6F............................. : Ok
Module : 116............................ : Module ID 116 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 118............................ : Module ID 118 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 119............................ : Module ID 119 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 68............................. : Module ID 68 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 69............................. : Ok
Module : 6A............................. : Ok
Module : 120............................ : Ok
Module : 12D............................ : Ok
Module : 04............................. : Ok
Module : 05............................. : Ok
Module : 3700........................... : Ok
Module : DE............................. : Ok
Module : B6............................. : Ok
Module : D5............................. : Ok
Module : 3426........................... : Ok
Module : 3424........................... : Ok
Module : 3425........................... : Ok
Module : 3411........................... : Ok
Module : D1............................. : Ok
Module : DB............................. : Ok
Module : DF............................. : Ok
Module : DD............................. : Ok
Module : 3413........................... : Ok
Module : 3402........................... : Ok
Module : D7............................. : Ok
Module : D2............................. : Ok
Module : 3300........................... : Ok
Module : 3301........................... : Ok
Module : 3307........................... : Ok
Module : 3303........................... : Ok
Module : 3500........................... : Ok
Module : BB............................. : Ok
Module : 3400........................... : Ok
Module : 3407........................... : Ok
Module : 3405........................... : Ok
Module : D9............................. : Ok
Module : D4............................. : Ok
Module : 3305........................... : Ok
Module : 3429........................... : Ok
Module : DC............................. : Ok
Module : D0............................. : Ok
Module : D3............................. : Ok
Module : F7............................. : Ok
Module : BA............................. : Ok
Module : 3406........................... : Ok
Module : B9............................. : Ok
Module : BC............................. : Ok
Module : 3417........................... : Ok
Module : D8............................. : Ok
Module : BD............................. : Ok
Module : BE............................. : Ok
Module : 3401........................... : Ok
Module : 3302........................... : Ok
Module : 3304........................... : Ok
Module : 3501........................... : Ok
Module : 3502........................... : Ok
Module : 3416........................... : Ok
Module : 3F01........................... : Ok
Module : B8............................. : Ok
Module : BF............................. : Ok
Module : E6............................. : Ok
Module : E7............................. : Ok
Module : 34E7........................... : Ok
Module : 3802........................... : Ok
Module : 3801........................... : Ok
Module : 3418........................... : Ok
Module : 3423........................... : Ok
Module : 3422........................... : Ok
Module : 3511........................... : Ok
Module : 3421........................... : Ok
Module : 3503........................... : Ok
Module : 3F00........................... : Ok
Module : 3428........................... : Ok
Module : 3504........................... : Ok
Module : 8010........................... : Ok
Module : 802C........................... : Ok
Module : 8035........................... : Ok
Module : 8038........................... : Ok
Module : 803C........................... : Ok
Module : 8016........................... : Ok
Module : 801D........................... : Ok
Module : 8044........................... : Ok
Module : 8031........................... : Ok
Module : 8062........................... : Ok
Module : 8063........................... : Ok
Module : 8041........................... : Ok
Module : 8042........................... : Ok
Module : 800E........................... : Ok
Module : 802D........................... : Ok
Module : 8019........................... : Ok
Module : 802F........................... : Ok
Module : 8034........................... : Ok
Module : 802E........................... : Ok
Module : 8032........................... : Ok
Module : 8017........................... : Ok
Module : 8002........................... : Ok
Module : 800B........................... : Ok
Module : 8005........................... : Ok
Module : 8020........................... : Ok
Module : 8046........................... : Ok
Module : 8045........................... : Ok
Module : 8027........................... : Ok
Module : 8014........................... : Ok
Module : 801C........................... : Ok
Module : 8023........................... : Ok
Module : 801F........................... : Ok
Module : 803A........................... : Ok
Module : 803E........................... : Ok
Module : 8012........................... : Ok
Module : 8026........................... : Ok
Module : 802B........................... : Ok
Module : 8029........................... : Ok
Module : 802A........................... : Ok
Module : 8037........................... : Ok
Module : 803B........................... : Ok
Module : 800F........................... : Ok
Module : 800A........................... : Ok
Module : 8025........................... : Ok
Module : 8009........................... : Ok
Module : 800C........................... : Ok
Module : 8006........................... : Ok
Module : 8018........................... : Ok
Module : 800D........................... : Ok
Module : 8008........................... : Ok
Module : 8024........................... : Ok
Module : 8015........................... : Ok
Module : 8007........................... : Ok
Module : 8065........................... : Ok
Module : 801A........................... : Ok
Module : 8030........................... : Ok
Module : 801E........................... : Ok
Module : 8001........................... : Ok
Module : 8022........................... : Ok
Module : 8064........................... : Ok
Module : 8049........................... : Ok
Module : 805D........................... : Ok
Module : 805E........................... : Ok
Module : 805F........................... : Ok
Module : 8060........................... : Ok
Module : 8061........................... : Ok
Module : 8011........................... : Ok
Module : 803F........................... : Ok
Module : 8040........................... : Ok
Module : 8033........................... : Ok
Module : 8043........................... : Ok
Module : 8000........................... : Ok
Module : 8021........................... : Ok
Module : 8FFC........................... : Ok
Module : 8FFD........................... : Ok
Module : 8FFE........................... : Ok
Module : 8047........................... : Ok
Module : 8048........................... : Ok
Module : 8004........................... : Ok
Module : 8003........................... : Ok
Module : 8028........................... : Ok
Module : 8039........................... : Ok
Module : 803D........................... : Ok
Module : 8036........................... : Ok
Module : 801B........................... : Ok
Module : 8013........................... : Ok
Module : 804C........................... : Ok
Module : 804D........................... : Ok
Module : 804E........................... : Ok
Module : 804F........................... : Ok
Module : 804A........................... : Ok
Module : 804B........................... : Ok
Module : 8050........................... : Ok
Module : 8051........................... : Ok
Module : 8052........................... : Ok
Module : 8053........................... : Ok
Module : 8054........................... : Ok
Module : 8055........................... : Ok
Module : 8056........................... : Ok
Module : 8057........................... : Ok
Module : 8058........................... : Ok
Module : 8059........................... : Ok
Module : 805A........................... : Ok
Module : 805B........................... : Ok
Module : 805C........................... : Ok
Module : 8066........................... : Ok
Module : 8067........................... : Ok
Module : 8068........................... : Ok
Module : 8069........................... : Ok
Module : 806A........................... : Ok
Module : 806B........................... : Ok
Module : 806C........................... : Ok
Module : 806D........................... : Ok
Module : 806E........................... : Ok
Module : C3............................. : Ok
Module : C8............................. : Ok
Module : 1000........................... : Ok
Module : B1............................. : Ok
Module : B2............................. : Ok
Module : 1001........................... : Ok
Module : 1002........................... : Ok
Module : 1009........................... : Ok
Module : 100A........................... : Ok
Module : 1003........................... : Ok
Module : 100C........................... : Ok
Module : 1005........................... : Ok
Module : 1004........................... : Ok
Module : 1007........................... : Ok
Module : 100B........................... : Ok
Module : 100D........................... : Ok
Module : 100E........................... : Ok
Module : 1008........................... : Ok
Module : 91............................. : Ok
Module : AE............................. : Ok
Module : C2............................. : Ok
Module : AA............................. : Ok
Module : AC............................. : Ok
Module : 2904........................... : Ok
Module : C4............................. : Ok
Module : A2............................. : Ok
Module : C5............................. : Ok
Module : 2900........................... : Ok
Module : 2901........................... : Ok
Module : 2903........................... : Ok
Module : 2F00........................... : Ok
Module : 2802........................... : Ok
Module : 2909........................... : Ok
Module : 290A........................... : Ok
Module : 2A02........................... : Ok
Module : 1121........................... : Ok
Module : 1100........................... : Ok
Module : 150F........................... : Ok
Module : 150E........................... : Ok
Module : 150D........................... : Ok
Module : 150C........................... : Ok
Module : 1507........................... : Ok
Module : 1506........................... : Ok
Module : 1505........................... : Ok
Module : 1504........................... : Ok
Module : 1101........................... : Ok
Module : 1503........................... : Ok
Module : 1502........................... : Ok
Module : 1501........................... : Ok
Module : 1500........................... : Ok
Module : 80FE........................... : Ok
Module : 806F........................... : Ok
Module : 3604........................... : Ok
Module : 2077........................... : Ok
Module : 2076........................... : Ok
Module : 2075........................... : Ok
Module : 2074........................... : Ok
Module : 2073........................... : Ok
Module : 2072........................... : Ok
Module : 2071........................... : Ok
Module : 2070........................... : Ok
Module : 2067........................... : Ok
Module : 2066........................... : Ok
Module : 2065........................... : Ok
Module : 2064........................... : Ok
Module : 2063........................... : Ok
Module : 2062........................... : Ok
Module : 2061........................... : Ok
Module : 2060........................... : Ok
Module : 2057........................... : Ok
Module : 2056........................... : Ok
Module : 2055........................... : Ok
Module : 2054........................... : Ok
Module : 2053........................... : Ok
Module : 2052........................... : Ok
Module : 2051........................... : Ok
Module : 2050........................... : Ok
Module : 2047........................... : Ok
Module : 2046........................... : Ok
Module : 2045........................... : Ok
Module : 2044........................... : Ok
Module : 2043........................... : Ok
Module : 2042........................... : Ok
Module : 2041........................... : Ok
Module : 2040........................... : Ok
Module : 2017........................... : Ok
Module : 2016........................... : Ok
Module : 2015........................... : Ok
Module : 2014........................... : Ok
Module : 2013........................... : Ok
Module : 2012........................... : Ok
Module : 2011........................... : Ok
Module : 2010........................... : Ok
Module : 2037........................... : Ok
Module : 2036........................... : Ok
Module : 2035........................... : Ok
Module : 2034........................... : Ok
Module : 2033........................... : Ok
Module : 2032........................... : Ok
Module : 2031........................... : Ok
Module : 2030........................... : Ok
Module : 2027........................... : Ok
Module : 2026........................... : Ok
Module : 2025........................... : Ok
Module : 2024........................... : Ok
Module : 2023........................... : Ok
Module : 2022........................... : Ok
Module : 2021........................... : Ok
Module : 2020........................... : Ok
Module : 2007........................... : Ok
Module : 2006........................... : Ok
Module : 2005........................... : Ok
Module : 2004........................... : Ok
Module : 2003........................... : Ok
Module : 2002........................... : Ok
Module : 2001........................... : Ok
Module : 2000........................... : Ok
Module : 9A............................. : Ok
Module : A0............................. : Ok
Module : A5............................. : Ok
Module : A9............................. : Ok
Module : 97............................. : Ok
Module : 96............................. : Ok
Module : 94............................. : Ok
Module : C9............................. : Ok
Module : C6............................. : Ok
Module : 93............................. : Ok
Module : CE............................. : Ok
Module : CF............................. : Ok
Module : 98............................. : Ok
Module : 99............................. : Ok
Module : CA............................. : Ok
Module : CC............................. : Ok
Module : 128............................ : Ok
Module : 121............................ : Ok
Module : 3C00........................... : Ok
Module : AF............................. : Ok
Module : 9E............................. : Ok
Module : FA............................. : Ok
Module : C7............................. : Ok
Module : 3E00........................... : Ok
Module : FC............................. : Ok
Module : 280A........................... : Ok
Module : 9C............................. : Ok
Module : EE............................. : Ok
Module : 11............................. : Module ID 11 reading error Data request error - Device Error Detected: "FM ERR CHECKSUM"
Module : 01............................. : Ok
Module : FD............................. : Ok
Module : C1............................. : Ok
Module : B7............................. : Ok
Module : 5C............................. : Ok
Module : 122............................ : Ok
Module : 6D............................. : Ok
Module : 4002........................... : Ok
Module : AC55........................... : Ok
Module : 6E............................. : Ok
Module : 1F............................. : Ok
Module : 62............................. : Ok
Module : 61............................. : Ok
Module : 115............................ : Ok
Module : 53............................. : Ok
Module : 52............................. : Ok
Module : 51............................. : Ok
Module : 50............................. : Ok
Module : 12............................. : Ok
Module : 19............................. : Ok
Module : 24............................. : Ok
Module : 23............................. : Ok
Module : 21............................. : Ok
Module : 2A............................. : Ok
Module : 2F............................. : Ok
Module : 1E............................. : Ok
Module : 15............................. : Ok
Module : 14............................. : Ok
Module : 1C............................. : Ok
Module : 17............................. : Ok
Module : 02............................. : Ok
Module : 109............................ : Ok
Module : 108............................ : Ok
Module : 106............................ : Ok
Module : 105............................ : Ok
Module : 104............................ : Ok
Module : 103............................ : Ok
Module : 102............................ : Ok
Module : 110............................ : Ok
Module : AD............................. : Ok
Module : 1430........................... : Ok
Module : 1102........................... : Ok
Module : 121F........................... : Ok
Module : E0............................. : Ok
Module : E1............................. : Ok
Module : E2............................. : Ok
Module : E3............................. : Ok
Module : E4............................. : Ok
Module : E5............................. : Ok
Module : FE............................. : Ok
Module : 120F........................... : Ok
Module : 1213........................... : Ok
Module : 2906........................... : Ok
Module : 2908........................... : Ok
Module : E8............................. : Ok
Module : E9............................. : Ok
Module : EA............................. : Ok
Module : EB............................. : Ok
Module : EC............................. : Ok
Module : ED............................. : Ok
Module : 1400........................... : Ok
Posted: 20.02.12, 08:43
by hassan
Now try to rewrite module 11 from the same FW version
Posted: 20.02.12, 11:12
by rcz
I have "Error code 3745" when I try to write any module.
Posted: 20.02.12, 12:46
by hassan
Try to write modules by ID
Posted: 20.02.12, 17:53
by rcz
This error happens when I write by ID, I can't access to modules by ABA
Posted: 22.02.12, 07:03
by hassan
If you can read and write SA Tracks try to write the original SA tracks
Posted: 30.03.12, 09:52
by Towerrat79
Hassan
Thank your for the tip on rewriting the donor's original Service Tracks. I did this and the drive came back to life!
Frank
Posted: 29.01.14, 10:08
by mojimorady
hi
Actually I Need loader and Rom And Rom modules of this model
is that possible for you to share them with me ???
best regards
