No Module 107 for ROM Rebuild
Posted: 21.12.11, 02:34
by Continuum
I am trying to rebuild rom and rom modules for a Dragfly1, but they do not have module 107. How can we do this?
Re: No Module 107 for ROM Rebuild
Posted: 23.12.11, 10:56
by ACE_Admin
On new WDC Marvel drives, ROM image modules are empty, so you should look for same version ROM in our FW database.
You can get its version from "View 90 module information" command.
Most likely patient drive will not read the data with the ROM you will get from database. Each WD drive has unique parameters in its ROM's 47th module. So the next step is to recover 47th module from SA and write it to current ROM . The command is located within Tests->Service information->Work with ROM->Module 47 recovery.
