WD
Posted: 25.04.11, 10:37
by mojimorady
Dear guru
i have a hdd in the following specification :
now when i connect it to pc3000 , it is not detected , in kernel mode it detects its family and
when i start the utility its window load everything ok as follow :
Techno mode key
i tried to do " head map editting in ram " the following message came up :
Lib:
Offset (hex): 4000000
Map Size: 8
\x05\x01\x02\x05\x06\x07\x00\x00\x00
\x05\x00\x01\x02\x05\x06\x07\x00\x00\x00
ne head map found
now who knows what the probles is and what should i do ?
kindest regards
mojimorady
Re: WD10EARS-00MVWB0
Posted: 25.04.11, 13:20
by Igor
Launch utility in normal mode and paste here log.
Posted: 25.04.11, 14:09
by hassan
Are you sure this is all the lines show in kernel mode ?
Where is the info about module 20B?
I have two resources in my data base for Sadle G6 all have 20B moule
Re: WD
Posted: 25.04.11, 18:47
by mojimorady
Dear Igor
accept my regards
when i connected the hdd to pc3000 and turned it on it spinned up but after it reached
ready state , its spindle turned off , after that i enter the marvell family , and i pressed "autodetect"
in "normal mode" , after that i click on "utility start " , the following were shown :
sorry for long story i wrote , but it was all details .
thanks so much for your soonest reply
mojtaba morady
Posted: 25.04.11, 18:55
by mojimorady
Dear Hassan
hi
first of all i should thank for all your help to me
now may i know that what module 20B is for ?
i tried to found in both kernel mode and normal mode but i couldn't .
now please tell me how i can find it and send it for you ?
best regards
Mojtaba Morady
Posted: 26.04.11, 08:53
by Igor
Try to write to the patient PCB ROM from similar drive but other FW version (not 0051006A) and native (patient's) 47 ROM module.
Then launch utility in normal mode and paste here new log.
Posted: 26.04.11, 16:04
by mojimorady
Dear Hassan
accept my regards far from to you
due to guidance of Igor i need Rom from this family , but other Firmware version ( not 0051006A ) ,
i will very appericate you if send this file .
best wishes
Mojtaba Morady
Posted: 26.04.11, 18:02
by hassan
Dear Mojtaba Morady
you are welcome here is the rom for
WDC WD10EARS-00MVWB0 Ver 00250012
but the head map of my rom is different than your drive so copy also Module 0A
Posted: 30.04.11, 18:39
by mojimorady
Dear Igor
accept my regards
thanks hassan for sending Rom file to me , after i did what you said but unfortunately nothing happens
and the following are the logs in normal mode ( not in kernel mode )
I am waiting for you help
best regards
Mojtaba Morady
Posted: 03.05.11, 09:07
by Igor
HDD does not want to read SA.
Try to read SA via hot swap method.
Find similar donor, connect it to pc-3000, turn power on, launch utility, execute stand by command, unscrew pcb, screw pcb to the patient, execute recalibration command or just read sa modules.
Re: WD
Posted: 23.05.11, 10:49
by mojimorady
Dear Igor
accept my regards
after a month i find another same hdd .
the difference is just in its Rom version
i tried to do what you said but pc3000 reads all sa modules with error
what should i do ?
any help will be very apperciated
mojtaba morady
Posted: 23.05.11, 11:33
by hassan
Can you read SA tracks while Hot Swap?
Posted: 23.05.11, 12:11
by dmarques
The problem of the head map editing in RAM feature is not working is probably related to PCB or ROM.
But anyway, there's also problem on some head for sure.
Posted: 23.05.11, 15:01
by Igor
How did you read modules?
You should read it by ID.
Also what error did you get?
Try to launch head test.
If you can not read even SA tracks I suppose that you should to swap heads.
