WD800JD probable firmware problem
Posted: 23.02.11, 21:05
Hi This WD 80GB drive had a blown motor chip and so a donor board
was used and the ROM chip transplanted. The drive now spins up,
identifies and itself properly in PC3000 UDMA (see first picture).
But the Express testshow 100% failure to read on all sectors:
I ran the SA Surface Verification and Structure Test and you can see the errors below:
From a PC3KU test of a similar drive, I see that the errors point to S.M.A.R.T. errors.
So I attached a picture of the View Smart: (oops on 3 pix allowed!?) Basically it
has only 2 lines (with Id 0) that say "unknown parameter"
I have tried to Clear Smart, but I get an error, and then the drive starts clicking!
and I think there's a timeout error:
Other S.M.A.R.T. logs................... : S.M.A.R.T. clearing error (page 06) - Drive is not ready
I need help what to do next to get the data recovered.
Thanks!
Chris Lees
London, U.K.
Thanks!
Chris Lees
London, U.K.
