WD5000BEVT not spinning
Posted: 07.07.10, 08:10
by Continuum
I have a WD5000BEVT that does not spin.
When I put a donor board on the drive, it still does not spin. If I put the original board on the donor drive, it does spin up.
Platters are not stuck, nor are heads.
If I do a hot swap, however, the drive spins up(but clunks)
Has anyone seen this before and if so, what can I do to fix it?
Re: WD5000BEVT not spinning
Posted: 07.07.10, 08:44
by dobrevjetser
I've seen this when the preamp was bad, but dont remember which drive.
Anyway, i think you should change hda.
Dobre
Posted: 08.07.10, 11:17
Try power the disk with some paper isolated between HSA contact and PCB, but leave motor contact connected. If spindle starts, then almost certainly preamp is bad,
Posted: 10.07.10, 16:30
by pcimage
Does is make any noise at all?
Like a "buzz buzz" then nothing?
Posted: 12.07.10, 03:28
by Continuum
If you put your ear to it, you can hear the tiniest click when you apply power.
