Western digital Marvell ROYL and non-ROYL drives: hot-swap
Posted: 18.06.10, 15:14
Western digital marvell drives can be separated into three groups:
WD Marvell drives with classic CHS Header : 2.5 inch Scorpio , 3.5 inch Mammoth , Sabre53(Sabre), Sabre58(Unicorn), Bucaneer, Hawk, Zeus, Raider, Starling, Hawk2.
MWD-ROYL-CHS 2.5 inch : Orion , Aquarius
MWD-ROYL-ABA with access to SA through ABA coodrinate:
2.5 inch Aries, Lynx, McKinley, Cougar, Denali, Saturn, Mercury
3.5 inch Tornado, Sequoia, Tornado PATA, Jupiter, Tornado 2D, Sequoia PMR, STG Twin, Lakes, Tornado 2PMR, Tornado 2R, Atlantis, Pinnacle, Hulk, Spider, Kermit, Cypress, Gekko, Atlantis PATA, Pinclite Pinnacle PATA and other new families.
Hot-Swap method for CHS Header (worked well on Sabre53, but should also work on other drives with that type :
Donor has to be compartible with patient head map(donor head map should be identical to patient or more heads should exist. Unnecessary heads have to be turned off)
1. Read patient ROM and Tracks
2. Connect Donor drive and copy ROM , then copy all tracks from patient
3. Restart Donor. It has to reach ready state. If you are not sure in translator modules, you can recalculate them
4. Stop spindle motor with "Standby" command
5. Unscrew the board from donor and install it to patient
6. Perform Recalibration command
That method worked well for several Sabre53 cases. If anybody has tried that method on other classic WD Marvell drives, please report.
