What needs to be considering for WD HDA replacement
Posted: 11.12.09, 00:11
by hamidrcr
I am trying to recovery WD knocking hard, it is impossible to find exact match. Can some one explain what needs to be considering for Head stack replacement.
I tried same model #, same manufacture month, DCM close match notting works once in a blue moon I am able to recover.
I tired each and every thing for instance Head stack replacement, platter swap etc
Can some one please help me ?
Re: What needs to be considering for WD HAD replacement
Posted: 11.12.09, 00:30
by ZeBong
WD have the aligment issue.
That is not easy to do.
Posted: 11.12.09, 01:01
by N.C.
WD drive needs special headstack alignment, this is why you can't get any success.
Me and Pepe both can handle this problem, if you are interested.
Janos
Posted: 11.12.09, 01:17
by ZeBong
Me too
Posted: 11.12.09, 18:27
by hamidrcr
I am intersted.
please let me know.
Re: What needs to be considering for WD HDA replacement
Posted: 01.07.10, 08:09
by dai
Hi !
I've been seeking for the solution for WD head alignment for over years.
According to the topic by N.C. , it seems the MHA's place ajustment is important .
Actually I had known about the outline already and have some success, but in these days
most of the patients are over 500GB and impossible to get data.
Today, I drew an illustration. I hope everyone uderstand what I want to express.
Now the question is "What should I adjust ?"
The space between the HDA pivot and the MHA ?
The angle of those 2 parts ?
Best Regards
dai
- WD.gif (18.37 KiB) Viewed 20995 times
Posted: 24.09.10, 05:45
by dai
If anyone has found out even a small tiny info about this matter, please state, I'm still waiting for it !!
Posted: 24.09.10, 15:08
You might consider the possibility that while positioning of HSA is important, so is information stored within the disks firmware coding regarding the positioning. This info can also be modified to reflect alternative HSA positioning.
Posted: 25.09.10, 06:53
by dai
Hi AJ2008 !!
I guess the data regarding MHA's positioning can be stored in the MHA itself or in the PCB , and not stored in SA, because the positioning data should be recognized before reading its SA.
As far as I know, adaptive (variable) data is stored in PCB's ROM ,,,,,,,,,,
My idea is wrong ?
Posted: 29.09.10, 03:17
by dai
The following info is a copy from another site. Thanks to the original author.
Example for old models:
DCM: HSEHYV2AH
1- Motor (H)
2- Base (S)
3- Latch (E)
4- Bottom VCM (H)
5- Media (Y)
6- Headstack (V)
7- Actuator-Preamp (2)
8- Top VCM (A)
9- Separator (H)
According to this info, it is possible that the conditions for a proper donor MHA is,
Best : 4,5,6,7,8
Better : 5,6,7
How is this ?
I'm now verifying my hypothesis and getting some results little by little.
