WD Hulk. Healthy SA and Heads - but no access to surface
Posted: 16.09.09, 19:51
Was anyone able to fix this problem? We have got a couple of 1TB Hulks that SA Structure test and head test had no errors, but the drive did not allow getting the data from it.
Do you have any solution for this problem?
Here is the drive log:
Techno mode key
Cyl Count............................... : 86
SA SPT.................................. : 1280
Flash Dir reading....................... : Ok
ROM version............................. : 5C.1EG
ROM generation.......................... : 5C.1EG
Link table version...................... : 01.33.
Head map................................ : 0,1,2,3,4,5,6,7
Firmware version........................ : 005C001E
Service area:
SA dir reading.......................... : Ok
SA Copies avalabled..................... : Copy 0,Copy 1
Heads test
CHS Test
Cylinder to test........................ : -7
Heads to test........................... : 0,1,2,3,4,5,6,7
Head 0.................................. : Ok
Head 1.................................. : Ok
Head 2.................................. : Ok
Head 3.................................. : Ok
Head 4.................................. : Ok
Head 5.................................. : Ok
Head 6.................................. : Ok
Head 7.................................. : Ok
ABA Test
Techno mode key
Service area:
Heads test
CHS Test
ABA Test
