WD Hulk. Healthy SA and Heads - but no access to surface
sarmich15
Postby sarmich15 » 16.09.09, 19:51
Was anyone able to fix this problem? We have got a couple of 1TB Hulks that SA Structure test and head test had no errors, but the drive did not allow getting the data from it.
Do you have any solution for this problem?
Here is the drive log:
Techno mode key
Cyl Count............................... : 86
SA SPT.................................. : 1280
ROM version............................. : 5C.1EG
ROM generation.......................... : 5C.1EG
Link table version...................... : 01.33.
Head map................................ : 0,1,2,3,4,5,6,7
Firmware version........................ : 005C001E
Service area:
SA dir reading.......................... : Ok
SA Copies avalabled..................... : Copy 0,Copy 1
Heads test
CHS Test
Cylinder to test........................ : -7
Heads to test........................... : 0,1,2,3,4,5,6,7
Head 0.................................. : Ok
Head 1.................................. : Ok
Head 2.................................. : Ok
Head 3.................................. : Ok
Head 4.................................. : Ok
Head 5.................................. : Ok
Head 6.................................. : Ok
Head 7.................................. : Ok
ABA Test
pcimage
Re: WD Hulk. Healthy SA and Heads - but no access to surface
Postby pcimage » 16.09.09, 20:24
Have you tried a new PCB?
sarmich15
Postby sarmich15 » 16.09.09, 21:49
I haven't replaced the PCB but I did clean all the contacts. The client mentioned that the drive had been dropped when teh drive was turned off, so I am mot sure if is worth ordering parts. All head tests passed as wel as SA and ROM, but still no access to the data.
Any tips?
Thanks!
Postby AJ2008 » 17.10.09, 20:42
I am not so sure that the heads test feature on ROYL is 100% accurate...
N.C.
Postby N.C. » 18.10.09, 01:13
AJ2008 wrote:I am not so sure that the heads test feature on ROYL is 100% accurate...
But this drive have a ramp for heads.
And it was dropped when was off.
So maybe it was safe.
The problem is somwhere else...
I think in the firmware this time.
Janos
