How to turn off WD Marvell's heads in RAM
Posted: 27.08.09, 09:02
Now it is possible to turn off bad heads on Marvell drives and read the data from the good ones.
Here is an example of fixing Zeus drive with this method. After it was powered on it makes three loud clicks with its heads and then it powers off its spindle motor. Register leds show us [DRD] [DSC] - [ERR] - [AMN].
Your drive may click more times and you should just let it click until it will stop its spindle motor.
After we run utility it show us no ID.
1. Open WDC Marvell utility startup window and select "Kernel mode" option. Then press "Autodetect". Utility should find the correct family.Leave the jumpers in master mode as they were before.
2. Perform command like its shown.
3. Next dialog box should be displayed to you.
4. Here is the list of all physical heads. As it unknown what head is damaged , I set all heads to 0th head.
5. After you pressed ok, perform "Soft reset command" the drive will turn on its motor and this drive id will be displayed correctly.You can preform command Tools->Drive id to refresh the data.
If it is not possible to start up the drive from 0th head, you should try set 1st instead of it.
6. After the drive started to spin and its ID was shown, go to "RAM Head map change" menu again and set the head map to its original values.Then set soft reset once more. Now the drive is ready to read its data.
7. Run DataExtractor and build heads map. After the head map was built, you can read the data from healthy heads.
