WD Head Compatibility
Posted: 27.07.09, 07:13
There is a lot of contradictory info about DCM codes and matching heads on more current WD drives.
What should match on a donor for heads compatibility?
For example,
I've got a WD2500JS with a heads issue:
WD2500JS-00NCB1
DATE: 11 MAY 2006
DCM: DSCACTJAA
I've also got two drives from the same family in inventory, and wondered if either would be suitable donor:
#1) WD2500JS-22NCB1
DATE: 11 MAY 2006
DCM: HBCHTJCHN
#2) WD2500JS-60NCB1
DATE: 23 NOV 2006
DCM: HBBANTJAHB
My guess is that neither is close enough.
Thanks in advance.
For example,
WD2500JS-00NCB1
DATE: 11 MAY 2006
DCM: DSCACTJAA
#1) WD2500JS-22NCB1
DATE: 11 MAY 2006
DCM: HBCHTJCHN
#2) WD2500JS-60NCB1
DATE: 23 NOV 2006
DCM: HBBANTJAHB
Thanks in advance.
