wd3200aaks-00b3a0
Posted: 05.05.09, 11:33
Hi all
it seems that i can't get an access to the SA, the PC3k utility reads:
Techno mode key
RAM:
Zone allocation table................... : HDDs RAM reading error Techno CMD sending error Device Error Detected: "VSCE PERM OVL NOT LOADED"
SA SPT.................................. : 1311
Head number reading..................... : Ok
ROM:
ROM version............................. : 05.ARE
ROM generation.......................... : 05.ARE
Link table version...................... : 04.AD.
Head map................................ : 0,1
Firmware version........................ : 00010000
Service area:
SA dir reading.......................... : Ok
SA Copies avalabled..................... : NONE
Configuration reading................... : No SA copy avalabled
i can read the rom, the heads doesnt knock, heads test is fine, seems like the system area is not accessible or damaged.
i would apretiate any help you can give me on this topic.
Techno mode key
RAM:
ROM:
Service area:
