WD10EAVS-00D7B0
ZeBong
WD10EAVS-00D7B0
Postby ZeBong » 04.05.09, 22:49
Have this WD disk 1 Tbyte, that have head 0 and head 5 with error.
It have 1 953 525 168, so i make a head map and clone the other heads , them just clone the head 0 and 5 very slow but is cloning.
i make a SA structure test have here the report:
SA structure test.rar
(6.59 KiB) Downloaded 327 times
Can anyone look at it and reply.
ZeBong
aviko
Re: WD10EAVS-00D7B0
Postby aviko » 05.05.09, 12:22
not exact match but you can compare with mine:
report
Hdd res backup (profiles folder)
Hdd res export from db
Who does not know anything, must believe in everything
Re: WD10EAVS-00D7B0
Postby AJ2008 » 05.05.09, 13:09
2 of the damaged modules are of high importance for data access (Ad) and Sa access (As). I think these are the modules causing problems. You should look into trying to get these repaired, especially the Translator module that is damaged.
