WD1600
Posted: 29.01.09, 12:28
Hi Have this disk that the heads where stuck in the platte.
Remove the head to the park zone.
I could detect the disk and the DRD / DSC
Save the resources disk to the database
I start copy data in reverse.
But now the disk is not detect anymore.
When i start the utility it give-me two RED errors.
What should i do next.
Code: Select all
Techno mode key
Zone allocation table................... : HDDs RAM reading error Techno CMD sending error Device Error Detected: "VSCE PERM OVL NOT LOADED"
SA SPT.................................. : SA SPT determination error Techno CMD sending error Device Error Detected: "SERVO ERROR CODE BASE SvirLatchHang"
Flash Dir reading....................... : Ok
ROM version............................. : 09.9NF
ROM generation.......................... : 09.9NF
Link table version...................... : 03.8E.
Head map................................ : 0,1,2,3
Firmware version........................ : 0009009N
Service area:
SA dir reading.......................... : Unknown error. Code(0)
SA Copies avalabled..................... : NONE
Configuration reading................... : Module 02 not foundWhat should i do next.
