D400BD75MRA2 - VSCE drive protect locked
Posted: 13.01.09, 10:40
by tec
Hi there, Any idea on how to resolve/remove/open a "VSCE drive protect locked" situation from a WD400BD.
Re: D400BD75MRA2 - VSCE drive protect locked
Posted: 14.01.09, 15:20
by Alexandre Silveira
Which is the version of your PC3000 ?
Alexandre Silveira
Posted: 14.01.09, 16:18
by tec
Hi there Alexandre, Version 4042491
Posted: 15.01.09, 12:09
* If you want datarecovery you will be able to execute the procedure of HOT SWAP method that the area of data of the HDD with defect is possible to get access.
Alexandre Silveira
Posted: 15.01.09, 13:59
by tec
Thank you Alexandre
Posted: 16.01.09, 13:27
by tec
The solution for this drive in removing the VSCE drive protect locked is to overwrite module 02 - Configuration (HDD ID)
