WD1200JB-00FUA0
Posted: 27.12.08, 13:21
by ZeBong
Have the disk that when arrive to me the disk dont give the ID.
I try to cut some heads to see if it works but nothing happen.
Afther one week get back to the disk, and now it can give the ID.
Techno mode key:
HDD geometry loading.................... : Ok
Cyl Count............................... : 15468
Head Count.............................. : 4
SPT..................................... : 900
ROM version............................. : 15.BE.
SA FW version........................... : 15.BER
Link table version...................... : 05.66.
Serial ROM:
Heads configuration..................... : From map
The number of heads in use.............. : 4
Disabled heads.......................... : Yes
Head map................................ : 0,1,4,5
Service area:
Modules table loading................... : Ok (Copy 0)
Configuration loading................... : Ok
Translation overlay checking............ : Ok
SA surface verification
Initial cylinder........................ : -1
Final cylinder.......................... : -20
Head.................................... : 0,1
Cyl -1 Head 0........................... : Errors : 0
Cyl -1 Head 1........................... : Errors : 0
Cyl -2 Head 0........................... : Errors : 0
Cyl -2 Head 1........................... : Errors : 0
Cyl -3 Head 0........................... : Errors : 0
Cyl -3 Head 1........................... : Errors : 0
Cyl -4 Head 0........................... : Errors : 0
Cyl -4 Head 1........................... : Errors : 0
Cyl -5 Head 0........................... : Errors : 0
Cyl -5 Head 1........................... : Errors : 0
Cyl -6 Head 0........................... : Errors : 0
Cyl -6 Head 1........................... : Errors : 0
Cyl -7 Head 0........................... : Errors : 0
Cyl -7 Head 1........................... : Errors : 0
Cyl -8 Head 0........................... : Errors : 2
Sectors :Error
304.....................................
319.....................................
Cyl -8 Head 1........................... : Errors : 0
Cyl -9 Head 0........................... : Errors : 0
Cyl -9 Head 1........................... : Errors : 0
Cyl -10 Head 0.......................... : Errors : 0
Cyl -10 Head 1.......................... : Errors : 0
Cyl -11 Head 0.......................... : Errors : 0
Cyl -11 Head 1.......................... : Errors : 0
Cyl -12 Head 0.......................... : Errors : 0
Cyl -12 Head 1.......................... : Errors : 0
Cyl -13 Head 0.......................... : Errors : 0
Cyl -13 Head 1.......................... : Errors : 0
Cyl -14 Head 0.......................... : Errors : 0
Cyl -14 Head 1.......................... : Errors : 0
Cyl -15 Head 0.......................... : Errors : 0
Cyl -15 Head 1.......................... : Errors : 0
Cyl -16 Head 0.......................... : Errors : 0
Cyl -16 Head 1.......................... : Errors : 0
Cyl -17 Head 0.......................... : Errors : 0
Cyl -17 Head 1.......................... : Errors : 0
Cyl -18 Head 0.......................... : Errors : 0
Cyl -18 Head 1.......................... : Errors : 0
Cyl -19 Head 0.......................... : Errors : 0
Cyl -19 Head 1.......................... : Errors : 0
Cyl -20 Head 0.......................... : Errors : 16
Sectors :Error
1.......................................
11......................................
15 -- 16................................
20 -- 21................................
25 -- 26................................
30 -- 31................................
35 -- 36................................
40 -- 41................................
45 -- 46................................
Cyl -20 Head 1.......................... : Errors : 24
Sectors :Error
10 -- 11................................
17......................................Drive is not ready
22......................................Drive is not ready
27......................................Drive is not ready
32......................................Drive is not ready
37......................................Drive is not ready
42......................................Drive is not ready
47......................................Drive is not ready
SA surface verification completed
Make a head test :
it gives OK,
Heads test
Cylinder to test........................ : -25
Heads to test........................... : 0,1,2,3
Head 0.................................. : Ok
Head 1.................................. : Ok
Head 4.................................. : Ok
Head 5.................................. : Ok
But some times i have to test head by head to give head ok
Try to build a head maps but it give error.
Error execute=LBA to CHS convert error Device Error Detected 51/04 (ABR)
