WD1600BEVE - 22WZT0
Posted: 25.09.08, 21:31
by Towerrat79
I have a WD1600BEVE - 22WZT0 Which makes a sound as if wire were either breaking or hitting the top of the case. When
I ran PC 3000udma in McKinley mode I receive the following information:
Techno mode key:
Tech on................................. : Ok
ROM version............................. : 01.09A
ROM generation.......................... : 01.09A
Link table version...................... : 01.27.
Heads number in use..................... : 3
Head map................................ : 0,1,2
Firmware version........................ : 00010009
Techno mode key:
Zone allocation table................... : HDDs RAM reading error Techno CMD sending error Device Error Detected 51/04 (ABR)
Drive is not ready
SA SPT.................................. : SA SPT determination error Techno CMD sending error Drive is not ready
Heads number............................ : 3
ROM Data size........................... : 0 Kb
Service area:
SA dir reading.......................... : Unknown error. Code(0)
SA Copies avalabled..................... : NONE
Translator regeneration
Regeneration method..................... : Use P-List only
HDD Readiness timeout (10000 ms) D0 / 00
Heads test
Cylinder to test........................ : -10
Heads to test........................... : 0,1,2
Drive is not ready
Head 0.................................. : Error W : 1
Head 1.................................. : Skip
Head 2.................................. : Skip
Running DataExtractor I received the following
PC-3000 UDMA
The drive does not support LBA mode or the ID Drive was read incorrectly!
OK
What would my next step be?
Frank
Re: WD1600BEVE - 22WZT0
Posted: 30.09.08, 15:43
by Igor
Hello Towerrat79,
The problem into this case should be in PCB.
You should to find a donor drive for HotSwap.
If you want to know more about HotSwap you can read our utility for Western Digital 8.4 HOT-SWAP method.
REgards.
Posted: 01.10.08, 16:32
by Towerrat79
Igor
Thank you for the reply. For my knowledge, where did you see that the PCB should be the component that is causing me problems?
Frank
