WD 5000AAJS SA Problem
Posted: 10.06.08, 15:54
by d.rob
i am a new user of PC3000, i ve some problem with the SA of this drive.
maybe i need to writte modules?
hard drive is detected as: Marvell Tornado
SA SPT: manually, default value 500 doesn't work....
SA tracks, SA Surface, are OK, all in ROM too.
But no modules in SA found.
and here the log at supply:
Techno mode key:
Tech on................................. : Ok
Zone allocation table................... : HDDs RAM reading error Techno CMD sending error Device Error Detected 51/04 (ABR)
SA SPT.................................. : SA SPT determination error Techno CMD sending error Device Error Detected 51/04 (ABR)
ROM version............................. : 21.68Q
ROM generation.......................... : 21.68Q
Link table version...................... : 22.50.
Head map................................ : 2,3,4,5,6,7
Firmware version........................ : 00210068
Service area:
SA dir reading.......................... : Unknown error. Code(0)
SA Copies avalabled..................... : NONE
thanks, and nice to meet you ACELab community! :)
Posted: 19.06.08, 15:35
by Igor
Hello d.rob,
This error appears because of uncorrect instalation process.
So, reinstall the utility.
Posted: 23.06.08, 18:28
by d.rob
hello!
i've reinstall PC3000 UDMA utility from the CDrom, new act file...etc but the problem of code 0 still, is it an installation problem at 100% ?? the hard drive is a marvell familly, tornado. maybe tornado is not supported, or less than others.
Posted: 24.06.08, 11:32
by Igor
Hello d.rob,
Could you publish a report after:
1) trecks reading(except - 1)
2) checking LBA range(from 0 to 9)
