WD5000KS & WD5000AAKS head swap
Even with identical donors, cleanroom and careful operation, headswap fails on WD5000KS & WD5000AAKS model drives. Anyone has solution, trick or advice on this?
Re: WD5000KS & WD5000AAKS head swap
I have the same situation for one WD4000KS-00MNB0.
With corect head map the hdd it's clicking 3 times and after that stop.
If I modify head map and I disable heads 4,5,6,7 the hdd is initilizing and I can read all the modules from head 0.
So in this case was necessary to swap the heads, I used one donnor bougth in the same day(perfect compatible) and I made the head swap, but surprise, with the new heads I can't read nothing from the hard drive, the hdd is not initilizing.
I made a lot of headmap modifications but nothing.
I put back the original heads this are working well but without that 4 heads.
But I need the complete image.
Acelab will soon release some solution for head problems on big WD drives. Until then, there is no point in wasting the donors...
I can help you with these and other WDs, if still needed. We have good solution for dealing with such drives.
pepe
pepe
