I recently had a number of WD scorpio drives such as WD800UE - 22HCT0. They are all detected as WDC ROM Model Scopio.
After swapping rw head stack, swapping pcb (with resoldering of rom chip from patient to donor), none of them work.
I tried to perform hot swap but it will also fail because I realize even two drives with similar label such as WD800UE - 22HCT0 will not work after pcb swap without the rom resoldering so hot swap will never get the recalibration work correctly.
I begin to wonder if any one had encounted such problem before with any success at all ?
A run with the udma shows the following error:
Zone Alliocation Table : HDDs RAM reading error Techno CMD sending error device error detected 51/04 (ABR)
SA SPT - SA SPT Determination error Techno CMD sending error device error detected 51/04 (ABR)
SA Dir Reading -Device Error detected
Configuration reading - Module 02 not found
WD Scorpio Data Recovery
