SAFE MODE for marvel SATA PCBA
misa
Postby misa » 04.12.07, 12:53
How can I do for passing the tech commands ?
It's SATA controller of WD RAPTOR WD1500ADFD drive.
I jumped SSC-SEL, PM2 and OPT1 -> After power on drive switched to ready status, but when I want to read ROM I can't change ROM.
I read that short circuit one point with GND and it'll work. (but wich point ?)
Misa
Vadim
Postby Vadim » 03.02.08, 18:12
Did you try to start safe when PCB without HDA?
Best regards, Vadim Morozov
ACE Laboratory technical director
misa
Postby misa » 04.02.08, 10:17
Yes I tried and it's the same !
Vadim
Postby Vadim » 04.02.08, 12:57
OK! I'll try to solve this problem. Give me time.
Vadim
Postby Vadim » 05.02.08, 18:55
I think two jumpers: SSC SEL and PM2
misa
Postby misa » 06.02.08, 16:49
Thanks for your answers.
I jumped board has you said, but when I power ON, busy light green during 2 sec and after light off. I tried to read ROM without success.
I changed the head map on drive.
When I modified ROM, I start drive in Normal mode, now when I start drive in Normal mode drive click.
So I want to return native configuration, and I don't know how to do
I used PC3000 UDMA ver 3.2.1.
Misa
