It has 7 pins. You can see this chip in red square:
We have noticed that there are 3 types of voltage regulator manufacture exists:
- IRU1239SC (International Rectifier)
- TLE4417 (Infineon)
- ST3L01 (ST Microelectronics)
Taking PCB off from HDD and giving Power On, we use multimeter we check voltage at each of the pin. We found that IRU1239SC and TLE4417 have same results.
But ST3L01 voltage regulator chip is different from first two.
We have checked voltage at IRU1239SC and TLE4417 and got next results below.
Approx. pin's voltage:
1 - 1.2 V
2 - 3.2 V
3 - 5 V
4 - 0 V
5 - 1.2 V
6 - 12 V
7 - 2.6 V
From this test we could see that pins 3 and 6 are input and rest of them are output.
For ST3L01 voltage regulation chip are the next results:
1 - 0 V
2 - 3.2 V
3 - 5 V
4 - 0 V
5 - 8 V
6 - 12 V
7 - 2.5 V
As a result we can definitely conclude that IRU1239SC and TLE4417 chips could be replaced by each other,
but ST3L01 voltage regulator could be replaced by the same chip only.
